FAT BIKES
WINTER APPAREL
TRAINERS
Page 3 of 3 FirstFirst 1 2 3
Results 51 to 59 of 59
  1. #51
    Reputation: Bataivah's Avatar
    Yea, I just skipped it cuz I know what works best for me already.
  2. #52
    Reputation: MTBerNick's Avatar
    Oct 2012
    Quote Originally Posted by AndrwSwitch View Post
    How was your ride?
    Short and sweet, I woke up late so I only had time to do a 6 mile loop, it was not very technical, mostly flat. I did not have any mishaps due to not getting un-clipped in time. Getting clipped in still takes me a few tries. I did not ride long enough or ride anything technical enough to really compare, the only difference is the odd sensation of being attached to the bike. Hopefully tomorrow I can get my @$$ out of bed early enough to get a good ride in for a legit ride report.
  3. #53
    The fast bumpy stuff and climbs is where I notice the most difference. ie fast and rooty sections.
  4. #54
    Jan 2009
    Quote Originally Posted by MTBerNick View Post
    1. They are way too easy to "un-clip" so I do not see how this could discourage anyone.
    2. It takes ZERO form to bunny hop. Which is cool for me, bunny hopping is not my strong suit.
    1. if they are truly TOO easy, that can be solved, easily. on spd-type pedals, you can turn a bolt to tighten the pedal's grip on the cleat. or use a cleat with more/less float. on Crank Bros, you can orient the cleat a different way to tighten it up.
    2. doing a bunnyhop and doing a GOOD bunnyhop had nothing to do with your pedals. I can bunnyhop 24" on a bmx bike with platforms but I can probably get 8" on my 29er clipped in. it's all about form and how your bike is set up.
  5. #55
    Oct 2012
    Quote Originally Posted by mack_turtle View Post
    1. I have SPD's. I did play with the tension and turned it way up.
    2. But it CAN have alot to do with pedals, I can only do a solid 4 or 5 inches with platforms b/c I don't have good form. While clipped in I just yank on the bars and pull my legs up. If I practiced the same technique on platforms I would be yanking up on the bars and hopping off the pedals.
  6. #56
    I used to bunny hop on my BMX, but don't really do it much on a mtb/trail riding. Any air I get is usually the same with or without clippless on. Although I can lift the bike while in the air, it was'nt
    one of the reasons I went to them. It is an added bonus I suppose.
  7. #57
    Inspector Gadget
    Reputation: abeckstead's Avatar
    Feb 2012
    I like both. I rode in the 90's with toe clips and just started riding again in march. I started with some good flats and about 2 months ago I went clip less.
    I think starting with flats is the best way to go. It allows the ability to learn bike handling skills and removes the mental block of being stuck to a bike.
    I adjusted to clip less after a handful of rides. It's hard to explain but I feel they allow even more bike control in some situations. But I felt I needed to be over the "I know what my bike/body can do" hump to give them an honest try.
    As you've probably read though, people will make a case for either. Try both and draw your own conclusion.
    I hope you have a big trunk... cause I'm gonna put my bike in it!
  8. #58
    Dec 2012
    Clips all the way . Road, mountains, no matter.
  9. #59
    Dec 2012
    always just been comfortable on platforms just bought a redline monocog flight last week and just getting into mountainbiking and took my old odyssey pedals off of my old bmx and now they are on my redline
Follow MTBR on Facebook
