pinch flats
I got my first pinch flat this past weekend and ended up walking/carrying my wounded bike 4 miles with no spare tube or any means of repair, needless to say I learnt my lesson. I am wondering if there are any steps or tricks to avoiding this kind of flat tire like different air pressures or if it was just something based on luck and is unavoidable?
up your air pressure
or go tubeless
and always bring a spare tube, tire irons, patch kit, pump and tools.
ride like you stole it
^ +1 If you like low pressure go tubeless my tires are happily running at 20psi.
I lubed my disc brakes because they squeaked.
Man was that fun to work out
What nomit said.
Also, use your legs as shock absorbers, and try to ride smoothly. Lighten your bike as you approach rocks. You don't need to get airborne, just push off lightly so that only the bike's weight is banging against the rocks, rather than bike weight plus rider weight. In addition to reducing pinch flats, focusing on smoothness will make you a better rider overall.
+1. im all for tubeless. had 2 pinch flats in 2 rides... that was the line. im a light person (135lbs) and i was running fairly high pressures (32psi) with steel beaded tires.
tubeless is expensive so i did the ghetto method.
http://www.youtube.com/watch?v=WRM7gq1fcoQ
i know i throw this vid around a lot but it seemed to have helped a lot of people. have fun. remember your tire fixing kit next time.
- You may not post replies
- You may not edit your posts
Forum Rules
