Results 1 to 26 of 26
    Serenity now!
    Reputation: PixieChik's Avatar
    Are pedals universal?
    I just spent 30 minutes screwing my brains out trying to get my new Vault DMR pedals on my Yeti. I screwed backward, I screwed forward....no go.
    This fruitless effort was made worse by the fact that as I helplessly watched, the sun slid behind the horizon and my limited riding time evaporated.
    Plus I think I had a small stroke. On the positive side, my head did not actually explode.
    Duchess of Dab
    Beer Me!
    Reputation: Guerdonian's Avatar
    The thread on a pedal is universally 9/16-20, for all 3 piece cranks on modern bikes. There is a left and a right pedal. One has reverse thread, most have a stamp with L or R to help you out on this one. I have done this as well
    Unless you have an old bike with an older crank, read pre 80's, with a funky crank, all threads are the same.
    "Any wheel size is better than sitting at a computer all day." -Myself
    Reputation: MTBerNick's Avatar
    Oct 2012
    Almost all MTB pedals are 9/16 thread. The the thread rotation is different per side, the right side threads in traditionally (righty-tighty) the left side is opposite(lefty-tighty). Hope this helps.
    Screw right pedal to right crank arm, left pedal to left crank arm( left threaded )
    Serenity now!
    I knew I was missing something. I must have succeeded by dumb luck on previous pedal installations.
    Thanks.
    Duchess of Dab
    Serenity now!
    Good grief. I finally figured out right and left by looking it upon the DMR website.
    I was baffled by the smooth circular cuff on the pedal. No crescent wrench flat spots- how to screw it in? I tried my fingers, duh-that didn't work. Adjustable wrench- that couldn't be right, it was going to scratch up the cuff and potentially mangle the threads. Finally my husband suggested an Allen tool. It's inserted in the inside end of the pedal. How awkward.
    ( my husband laughed and told me I need a husband when I asked him what I was doing wrong. He is used to me trying to do things without his help- he just stands back and shakes his head.)
    But the pedals are on and I learned something new.
    Sometimes it sucks being a girl (but not all the time). It seems like men are born knowing things that are a mystery to me.
    Duchess of Dab
    Oct 2012
    since 4/10/2009
    Reputation: Harold's Avatar
    Almost. Most of us just start tinkering at a young age and figure things out, or we help our fathers at a young age. My sister is almost as mechanically capable as I am, and only because she didn't start with mechanical stuff until I left the house when she was 14. She's better with mechanical things than with domestic things. Her husband is the one who knits and has no mechanical skills at all (not kidding).
    I have many skills. I can wrench on a bike or a car, and I can sew (or, use a thread injector to make gear, yeah).
    Fat & Single
    Reputation: ozzybmx's Avatar
    Quote Originally Posted by PixieChik View Post
    Theres as many guys are clueless to bike stuff as women, guys are worse as they try and act as if they know
    You've done well
    Evil Following
    Trek 9.9 Superfly SL
    IndyFab Deluxe 29
    FM190 Fatty
    Pivot Vault CX
    Cervelo R3 Disc
    Kitty! Kitty! Kitty!
    Reputation: GelatiCruiser's Avatar
    Oct 2012
    Pedals we get. Women? Not so much.
    Picture Unrelated
    Reputation: zebrahum's Avatar
    Jun 2005
    So now that you have them on, did you grease the threads before you installed them? It's sort of important...
    Serenity now!
    Quote Originally Posted by GelatiCruiser View Post
    Heehee...yup.
    You're f*cking with me on the grease, right? They seemed kind of clear-greasy but I didn't actually put any grease on them. Why is that important?
    Duchess of Dab
    Beer Me!
    You need grease so that it won't seize in the crank over time from corrosion and crap. No joke, it should be applied.
    Its good you try stuff, better than the wife that is always just asking you to do things without even trying. Though I also must admit to snickering at my wife a little when she does stuff like what you are going through.
    Picture Unrelated
    Jun 2005
    Heehee...yup.
    Like Guerdonian said, if you ever want them to come off they need to be greased. Remember that if it has threads, then you need grease or anti-seize or Locktite or something. If you don't you risk those threads never coming undone.
    I just spent 30 minutes screwing my brains......... I screwed backward, I screwed forward....no go.
    I am glad you got them on.....I have a problem with right and left so it always takes me a while to figure it out....simplest thing is to just change one at a time that way you can compare the threads and figure it out easy.
    Fixed the OP for you.
    Anit seize or grease, makes it easy to get off later....the white bike grease is probably easiest. nickel based anit-sieze probably works the best.
    Serenity now!
    OK, back to square...seven. I'll check with my LBS bike boys to get the appropriate greasy substance.
    Duchess of Dab
    Beer Me!
    If you want on "do all" grease I would recommend the park tools Polylube. Works for many bicycle maintenance applications, I have had good luck with it:
    Park Tool Co. PPL-1 : PolyLube 1000 Lubricant (Tube) : Cleaning & Lube
    Sep 2012
    Motor oil? Petroleum jelly? Baby oil? Cooking oil? Crisco? Butter? Lard? They all work as an anti sieze in a pinch, especially when you are not subjecting it to high temps.
    As a woman you should at least know where you keep some of those on the list above.
    -S
    since 4/10/2009
    I have a tube of Phil Wood waterproof grease (the green stuff) that has lasted me several years. It's done well for me over that time.
    Reputation: mitzikatzi's Avatar
    Quote Originally Posted by jeffscott View Post
    I..snip.. nickel based anit-sieze probably works the best.
    I don't have the cans in front of me to check.
    I have a feeling Nickel based anti seize is not good for aluminum and the copper based ones are better.
    I just use grease on my bikes. Some say this is the go Bel-Ray Waterproof Grease
    Duct tape iz like teh Force. It has a Lite side and a Dark side and it holdz the Universe together.
    Reputation: Deep Thought's Avatar
    Sep 2012
    Go on ...
    In the future, to identify which pedal is which, hold them both with the spindles (the threaded parts) pointing upwards. If you look closely at the threads, you'll see that they are not exactly parallel with the ground, rather, they slant ever so slightly. On the left pedal, the threads slant slightly up toward your left. On the right pedal, the threads slant slightly up toward your right hand.
    Also, many mechanics actually prefer to use an allen key on the end of the spindle, myself included. A couple reasons for this are:
    - If you're in a hurry, it's faster, because you can just twist the allen key to thread them on or off very quickly.
    - You don't have to have a pedal wrench. Just allen keys, which you should have anyway.
    - You don't have to worry about scratching the crank arm, which is very easy to do with a pedal wrench.
    Oct 2012
    Quote Originally Posted by NateHawk View Post
    My mother still tells the story of the "Day my father got a new lawnmower." Apparently he spent over an hour trying to get the grass-catcher bag on the back. I walked up (6-8yo at the time), said "let me try" and put it on in 10 seconds flat.
    I am told he didn't know whether to be proud or cry.
    Dec 2012
    Sep 2012
    Quote Originally Posted by corbidougu View Post
    Uhh ... thanks Helpy Helperton. We've got that figured out already.
    Quote Originally Posted by shibiwan View Post
    Motor oil? Petroleum jelly? Baby oil? Cooking oil? Crisco? Butter? Lard? They all work as an anti sieze in a pinch, especially when you are not subjecting it to high temps....S
    I find this to be generally bad advise. Thin oils will wash out over time. Cooking oils/"greases" can dry our over time (ask my niece that used Pam on her sewing machine).
    To the OP...In the future, you might find the "how to's" at Park Tool helpful for working on your bike. Most things are covered. Congrats on doing things yourself.
    Serenity now!
    Quote Originally Posted by gmcttr View Post
    I have to assume shibiwan was being sardonic in making those bike-grease-substitute suggestions.
    Thanks, Jedi Masters, and thanks for the Park Tool link. That looks like one useful website!
    Duchess of Dab
