1. The most important thing about buying a new
bike is to make sure it fits. The only way you'll know if the bike is right
for you is to size up the bike and make sure that the bike's geometry matches
your body's geometry. Ask questions and do some research.
2. If possible, try to find a shop that will
let you demo the bike on real dirt. Five minutes in a parking lot won't cut
it. You wouldn't buy a car without a real world test drive, and a bike should
be no different.
3. Don't belive the hype. Just because
your favorite rider or best friend rides a certain bike, that doesn't mean
that's the best one for you. Have an open mind and be realistic about your
needs and ability.
Pedal Change
Now I'm pissed. I used a 15mm open end wrench to get my right pedal off (standard thread). Happy happy happy. Left pedal (reverse thread), total destruction. That pedal is still on there. The outside is damn near completely rounded off, and I can't get enough leverage to get the Allen key to wrench it off, even with multiple applications of penetrating oil. I'm nervous about rounding out the hex and then being COMPLETELY SOL. If I was working with a motorcycle or a car, the fix is simple: Hit the f**ker with a torch and then try. I can't see heating my crank with an oxy-asetelyne torch. Suggestions?
"Faster, Faster until the thrill of speed overcomes the fear of death." - Hunter S. Thompson
Use a dremel tool to flatten off the sides?
Sent from my SAMSUNG-SGH-I747 using Tapatalk 2
Heat it with a hair dryer, and apply more penetrating oil.
One more vote for the vise grips
Plus more torque, use a longer wrench or a cheater bar. If you cant keep a grip on it bust out a vise if you have one. A strong steady platform can make a huge difference.
BINGO, we have a winner, grind both sides down and use a smaller spanner, you will just have to do a bit of measuring.
Put the spanner on and use a rubber mallet n give it a good tap to get it happening, cheers
PARRAMATTA EELS R.L.C Life member- BLUE AND GOLD NEVER FOLDS..
'Lifes not about winning or losing, lifes about choosing'
I'd put a cheater bar on the allen key. If you round it you're no worse off then you are now. Every other option is leading you to destruction of the pedal (grinding flats, vice grips...) so you might as well start with the allen and then proceed to destruction if it doesn't work.
Should the allen not work either, I'd just drill out the axle until a vice grip will take it off.
Try hair dryer/heat gun, try the allen key. Can you get a vise grip on there without wrecking stuff? All else fails, drill a hole throu the spindle insert rod, screwdriver whateva, and turn.
Good luck
torx heads are good for removing partially stripped hex bolts.
Good luck
+1 this.
The ridiculousness of cycling clothes increase exponentially in relation to the distance from your bicycle.
Yeah, and getting the right angle/leverage, crankset in the right position is the key, or take off the crank arm or not but secure it with vise.
sawzall.... - kidding, vise grips always worked for me in the past
Could also strip down the pedal leaving the stuck spindle and put a pipe wrench on it.
^^^^^ This. Now you can use the torch on the spindle. Dont overhat the crap out of it. Heat will draw in the penetrating lube. As it cools down you should be able to back it out. If you work on cars you should have allen sockets. If allen doesnt do it by itself. socket on inside and a pipe wrench on the axle. This will even the force.
Good luck
Seeking MB-2 Fork (19.3), Ritchey FD post silver 26.8
Well I didn't try a saw or a pipe wrench, but after a spread wrench, two broken hex keys, several ounces of propane, two sets of guaranteed vice grips, and a can and a half of penetrating oil that pedal is still stuck on there. I give up. My LBS is opened back up now so I'll leave t to them. If they break the crank or anything, then they replace it. If I break something, its an expensive mistake (regardless of the opportunity to upgrade).
^^ LOL, greencanoe, i think you might find that after youve damaged your pedal that much that its not the LBSs fault if they break the crank, its a bit unethical to hold it against them to expect them to replace a broken crank after all tha damage you have done to it, get ready to fork out the cash to replace your own crank if the thread pulls out or it gets broken, and next time remember or learn how to remove a pedal properly,
And/or apply anti-seize when installing pedals. Dissimilar metals will gall, so a little lube makes a big difference.
Before you do anything destructive try this: Take a can of air, flip it upside down and spray the spindle with it for a good minute. Quickly hit the crank arm with a torch. Try removing the pedal with an allen.
Killing it with close inspection.
if you don't need to keep or if it's to late to save said pedal take the peddle off put the what is left of the pedal in to a vice with good teeth. Now use the bike as leverage, it also helps to have a helping hand in this.
The only reason that a left hand thread pedal is a problem is that someone turned it the wrong way out of ignorance.
Or that the bike shop that assembled the bike used locktite on the pedals. My LBS opened back up and we got the pedal off and found the smurf-sperm all over the threads.
I guess you mean it was blue loctite. Good enough reason. Red would have been worse. What would you have called it if it had been red?
spawn of the devil maybe
- You may not post replies
- You may not edit your posts
Forum Rules
