Results 1 to 8 of 8
    May 2013
    Ordinary or light tubes
    How does a tube weight affect the sturdiness of a tyre? I have Schwalbe Smart Sam 2.25 tyres with light Impac AV14 tubes (about 120g each). Is there any sense in installing ordinary tubes instead (about 200g each) or will I just increase the weight of my bike?
    Reputation: 006_007's Avatar
    You will just be adding weight. I always run light tubes.
    If you experience pinch flats frequently then maybe consider a heavier tube, or converting to tubeless.
    Just Ride
    Reputation: Cormac's Avatar
    try tubeless. Or so I've heard that's the best thing for mtb!
    SS ==> Nut up or Shut up!
    Reputation: JoePAz's Avatar
    May 2012
    I run nobby nics and regular tubes. Light tubes will save weight, but are more prone to damage do to the thinner material. If you can run thin tubes and not have an unacceptable rate of flats stay with them.
    Joe
    '12 Santa Cruz Highball 29", '13 Santa Cruz Solo 27.5",Vassago Verhauen SS 29" XC, AM, blah blah blah.. I just ride.
    May 2013
    OK, thanks everyone! This was really helpful. I will stick to light tubes.
    Reputation: CRchris1996's Avatar
    you can also fill the tube with any tubeless sealant and it will make it last a lot more
    Fat-tired Roadie
    Nov 2007
    Are your light tubes doing something to bother you?
    For me, for as little difference in price as there is, this is one of the places I choose to save a little weight. I could swear they roll a little nicer too.
    Re: Ordinary or light tubes
    Tubeless are overrated unless you ride in an environment where you get many flats. Been there done that.
    Light tubes is the best $/gram weight savings you can do. However, it can be annoying because they go flat quicker
  1. Are skinny/light tubes losing me float?
    By FishMan473 in forum Fat bikes
    Last Post: 12-29-2012, 08:30 PM
  2. Light weight, high volume tubes
    By roxtar in forum Wheels and Tires
    Last Post: 02-27-2012, 01:57 PM
  3. Light weight tubes
    By OLx6 in forum Weight Weenies
    Last Post: 02-16-2012, 11:24 AM
  4. Not So Ordinary Ordinary Bike
    By Clockwork Bikes in forum Frame Building
    Last Post: 11-26-2011, 12:44 PM
  5. Light Tubes 29?
    By poll in forum 29er Bikes
    Last Post: 02-17-2011, 04:10 PM
