Results 1 to 10 of 10
    Reputation: jazzanova's Avatar
    On-One bike, is it worth it?
    I am looking for a XC HT bike and found this one on sale, do you think it is worth it? My budget is $600-800 so this one would fit just in the middle.
    NEW 2011 On-One 456 custom mtb build 16" - $699
    -brand new seatpost, FSA Orbit headset, cables and housing.
    -Rock Shox Pike 454 u-turn air fork with 95-140mm adjustable travel
    -Sram X9 shifters and Sram X9 rear derailleur
    -Sunline V1 handlebar
    -Thomson X4 80mm stem
    -Hayes Nine Carbon hydraulic disc brakes
    -DT Swiss E455 rims on WTB Laser Disc Lite hubs
    THANKS!
    Reputation: dhbomber's Avatar
    Nov 2006
    The 456 is a nice bike...it's not custom geometry...so I don't know were the "custom" tag came from.
    I'm telling you this just for you to know...sometimes sellers add a little "spice" to the description...
    One thing you maybe aware of....the build of the bike is totally for All Mountain or very technical XC with lots of downhill. So if you ride very tame trails, or uphill a lot, you'll probably feel the heft of the bike...It seems it's gonna be in the 26 to 30 lbs of weight range. So take that in consideration.
    Parts are good overall...Pikes had good reputation. You can find spare parts easily.
    The only old thing on the bike are the brakes...They were pretty basic design...some minor flaws...just be sure you get new pads and possibly a rebleed.
    Good luck with your purchase!
    My Bike: http://forums.mtbr.com/showpost.php?...3&postcount=49
    On-One Whippet 650b XC machine
    Low Rep Count
    Reputation: 1SPD's Avatar
    Sounds like a decent build but as mentioned, might be a little on the heavy side of things. I have a couple of friends with On Ones and they are all quite happy with them. You certainly won't find something brand new with this level of parts at that price.
    Jul 2003
    Sounds resonable. the On One 456 is billed as a freeride hardtail. And it certainly fits the bill. The parts spec indicates the bike will weigh closer to 30lbs than 26, but that's to be expected. The only dubious parts on the bike are the wheels. DT 455s and WTB LSD Lite hubs are a bit on the "light" side for the bikes intended purpose. But if your riding style isn't "freeride aggressive" or are a fairly light rider then they likely won't be a problem. On One makes good frames, it should be a solid bike. Sounds like a good price to me.
    Good Dirt
    Picture Unrelated
    Reputation: zebrahum's Avatar
    Jun 2005
    Does it fit you? 16" frame isn't very big. Make sure you test ride it before you buy it, you'll have a better idea of it the bike is the type you'd like to ride after you ride it.
    I <3 dirt
    Reputation: Ilikemtb999's Avatar
    Oct 2010
    I love my 456. It's a great all arounder and climbs well. If it fits you I'd say go for it.
    The "custom" part I believe is referring to the build up of the parts on the frame; not the frame being custom.
    addicted
    Reputation: willrace4food's Avatar
    Jan 2009
    As the others have stated it sounds like a good buy at that price, but will be a heavy build for a XC bike. Which would be good for more aggressive trails save for the hubs, which could be replaced when they wear out. Overall I say it's a good find.
    I <3 dirt
    Oct 2010
    My 456 weighs 27lbs. Not bad at all for XC and not horribly different then this build.
    since 4/10/2009
    Reputation: Harold's Avatar
    make sure it'd fit. It's only a good deal if it fits.
    16" is small. Maybe 5'6" give or take could fit that frame depending on stem and seatpost. I'm 5'8" and fit about an 18" frame. My wife is 5'4" and fits a 15" frame, if that gives you much of an idea.
    T.W.O
    Reputation: pfox90's Avatar
    Aug 2010
    26 lbs lol yeah right... the geo is definitely aimed towards an all mountain type ride where you are ripping the downhills and getting back up the hill, isn't the best climber in the world, the front end comes up quite a bit isn't the best xc bike in the world... that being said steel is real and the bike is a blast to just whip around trails and to stunts, etc. really just depends on your ride style... its a good value for the money though
    ------__o
    ----_`\<,_
    ---(_)/ (_)
  1. Is this bike worth it?
    By JMHZ2401 in forum Beginner's Corner
    Last Post: 03-25-2011, 05:34 PM
  2. is this bike worth 500?
    By jason.jm in forum Bike and Frame discussion
    Last Post: 01-31-2010, 02:06 PM
  3. Replies: 4
    Last Post: 11-09-2009, 03:40 PM
  4. Is this used bike worth 150 USD?
    By frenchbulldog in forum GT
    Last Post: 06-25-2009, 08:28 AM
  5. New bike...worth it?
    By HFRCampbell in forum All Mountain
    Last Post: 06-04-2009, 08:27 PM
