1. The most important thing about buying a new bike is to make sure it fits. The only way you'll know if the bike is right for you is to size up the bike and make sure that the bike's geometry matches your body's geometry. Ask questions and do some research.
mtn. biking 101
2. If possible, try to find a shop that will let you demo the bike on real dirt. Five minutes in a parking lot won't cut it. You wouldn't buy a car without a real world test drive, and a bike should be no different.
3. Don't belive the hype. Just because your favorite rider or best friend rides a certain bike, that doesn't mean that's the best one for you. Have an open mind and be realistic about your needs and ability.
Results 1 to 7 of 7
Thread: Older bike
    Sep 2013
    Older bike
    Im getting back in the saddle and need a ride. I found an 03/04 kona dawg online for $500. I used to like kona frames but know that is kind of old. Any reason to pass this up? Also found an 04 Specialized stumpjumper fsr for $550. Thoughts?
    10 year old full suspension frames tend to need plenty of tlc, and finding the parts to do that might be difficult and costly. If i didn't have the funds for a current fs, I'd go with an ht.
    Old Fart Swamper
    Reputation: Osco's Avatar
    Apr 2013
    $500-550 burning a hole In your pocket ? yeah I agree with ou2mame.
    Or you could save up a little more while your looking and start with a much newer slightly used hard tail that would need nothing.
    Scott Spark 760
    I no longer clip In,
    got a better seat, and a dropper post.
    Other than It's Bone stock.
    It Just works :P
    Aug 2013
    I'm with them....and I just learned this lesson, so I'm paying it forward. My example is the '05 Blur I bought in June. Awesome bike, XT & XTR level components throughout. Bike had clearly been ridden, put a new chain, cassette, chainrings, and replaced the shifters and brake levers (had the dual controls, but RD shifter was sketchy). After a ride last week, found a crack between the pivot bracket and the seat tube.
    I'm going to pursue getting it repaired, because it may be worth it, but I went ahead an bought a shiny new Anthem Advanced yesterday.
    ETA: aluminum suffers from fatigue, which will eventually result in a failure. That's just fact of the material.
    '15 Anthem Advanced
    '05 SC Blur
    '94 Rockhopper
    Sep 2013
    Awesome. Thanks alot. That was kind of my concern.
    Cracking is more of an issue with certain frames, less with others (Blurs from that time period would be a lot more likely to crack than Dawgs). Lighter, racier bikes are usually more crack-prone. in general.
    Steel tends to hold up best, but you're not going to find much in the way of FS.
    Sinister Bikes
    Wraith Bicycles
    Sunday River Mtn Bike Park
    NEMBA
    Wachusett Brewing Co.
    Aug 2013
    Now ya tell me...
    '15 Anthem Advanced
    '05 SC Blur
    '94 Rockhopper
  1. Replies: 5
    Last Post: 07-06-2014, 04:25 PM
  2. Wanting to build a cross bike from and older road bike?
    By Drummerboy1975 in forum Cyclocross
    Last Post: 11-15-2012, 03:56 PM
  3. Older guy looking for Older bike parts for a 3x8 drivetrain.
    By Steel-is-real in forum Eastern Canada
    Last Post: 09-17-2012, 08:34 AM
  4. Replies: 7
    Last Post: 04-12-2012, 01:35 AM
  5. Replies: 0
    Last Post: 04-01-2012, 07:47 AM
