Results 1 to 16 of 16
    Reputation: Revivalll's Avatar
    OK to spray my bike down?
    I am an newb for about three months now and I have noticed quite a bit of dirt buliding up on some of my components. I wipe my bike down, especially the forks, clean my cogs and chain with a brush, and apply Pedros Ice stuff (whatever its called, to lazy to go to the garage) after every ride. But I am really tempted to take the hose to my bike, would it be ok if I sprayed it gently then wiped it down? Please dont tell my that I spent $800 on a bike and its not waterproof!
    Ancient Winged Rider
    Reputation: Dragoneyes's Avatar
    Yes, and you can use dish soap to wash it. Just dry it off and re-lube. Keep it clean and your bike will last longer and be less likely to break down on the trail....
    dont spray directly on to any bearings or parts that seem sensative. light mist should do. you still gotta scrub it. re lube and make sure it is completely dry before you lube.
    local trails rider
    Reputation: perttime's Avatar
    Aug 2005
    Just don't point pressurized water at any bearings and such.
    ...idios...
    Reputation: SteveUK's Avatar
    You may find the Basic Cleaning and Maintenance Guide useful.
    Diogenes
    Dec 2005
    Quote Originally Posted by Revivalll
    you'll be fine. i use simple green, engine degreaser, and a karcher pressure washer. my bike looks new all the time.
    mx
    Big Gulps, Alright!
    Reputation: Berkley's Avatar
    I hose mine down, but not often. It's crazy what tiny gaps the water will get into...
    Axle Standards Explained
    Founder at North Atlantic Dirt, riding & writing about trails in the northeast.
    I never clean mine as it will get dirty and muddy the minute I go back on the trail. However, I make sure that I keep my drive train and fork clean and lubed...but I don't care if the frame, wheels or tires are dirty!
    Dec 2005
    Quote Originally Posted by babu
    a clean bike is a happy bike and a mechanically sound bike.
    mx
    Quote Originally Posted by mx_599
    mx
    but its not a fun bike unless it get dirty
    oh Lucky me
    Reputation: Exodus11's Avatar
    ditto!
    when i do wash my bike, i use some simple green BIKE foam, a scrubby brush, and a garden hose. mainly just cleaning my drivetrain and forks. then i wait until the drivetrain is completely dry and re-lube. spin the cranks onto every gear, wipe the chain off.
    between washes, i use a shop towel to get the excess muck off my chain and freewheel. then lube it, spin it, wipe the excess and ride
    ...Dying is the easy part, its living that's the challenge...
    I Never will hose down my bikes. I have seen the damage it does no matter how careful you are. It is not catastrophic, but it will rust out bearings and any other steel part. (including corrosion of aluminum. Titanium corrodes from chlorine).You can do it, but you just need to make sure everything is dry, including every bolt head and bearing.
    Personally, I wait for mud to dry, then I just brush it off. I also keep my drive train clean and lubed with a chain lube that does not build up or collect crap. (I use Rock 'n' Roll but everyone has their preferences). Would you hose off a child if they were muddy? (some do). I personally take the time to wipe it down by hand if I want it to look pretty for some reason.
    I do understand though that some places just have that horrible mud that will never come off and hosing a bike is needed.
    I just hate to see the life of a perfectly good bike shortened because someone wants it to look pretty.
    Thank a Soldier Today
    Reputation: Gun5ling3rX's Avatar
    mx
    Since no one will say it, DONT USE A PRESSURE WASHER!!! Light pressure hose..avoid hubs, bearings, and bottom bracket. Dry, lube and your good.
    I would; however, like to know if simple green is useful and where...
    "Named must your fear be before banish it you can." -Yoda
    08 GF X-Cal
    08 GF Superfly (A Fisher called Wanda Su)
    If you think you can
    Reputation: 62kona's Avatar
    Anyone have any suggestions for someone living in an apartment? I have taken my bike to the car wash before and hosed it down. And i've wiped it down on our patio. Any other suggestions? Thanks.
    Vaginatarian
    Quote Originally Posted by JustFuzzIt
    water wont rust out bearings if they are properly greased,
    you would have to keep the aluminum wet for a very long time to get corrosion of any significance
    would you let the mud dry on a child and then scrub it off?
    this is a mountain bike not a watch
    there is nothing on a bike thats not on a car or motorcycle, do you not wash them either?
    you could wash your bike daily with soap & water and it wouldn't shorten the useful life
    in fact washing will actually lengthen the life of many components by removing the dirt and grit that will destroy the bearings faster than water will
    by letting the mud dry on the bike and wiping it off you are scratching the paint, and driving the grit into the greased areas
    virtually every manufacturer of frames and components recommends washing
    Vaginatarian
    Quote Originally Posted by 62kona
    take it out on the patio and get 1 bucket of warm water, pour it on the bike
    get a second bucket of soapy water (dish soap works fine) and a sponge and wash it
    get a third bucket of clean water and rinse
    bounce the bike to shake off free water, towell dry then clean & lube the chain
    finish line makes a pink wash that leaves a film that helps stop the flash rusting you sometimes get in bolt heads that have been scored
    the car wash is ok but keep the high pressure water away from any pivots or bearings
