Results 1 to 13 of 13
    Jun 2010
    offset or layback seatpost
    I'd like to get a little further back on my bike but I'm maxed out on the seat rails. I'm looking for a seatpost that has more than a 25mm offset, does that exist?
    Fat Is Where It's At Moderator
    Reputation: DiRt DeViL's Avatar
    Have you checked the Thomson?
    Needing that sort of post is a pretty good indicator that you're on a frame thats far too small! You should be able to find that sort of setback, but it'll put you in a pretty bad position for pedaling and overall bike handling.
    Probably drunk right now
    Reputation: Ken in KC's Avatar
    Quote Originally Posted by One Pivot View Post
    Really? I've been running a setback post for about 8 years on a bike that I absolutely love. The bike fits me great. My pedal position great. Bike handling is superb.
    For me, the setback post puts my riding position on FS bike in almost the identical position to my hardtail with a straight post.
    JPark - 3.5- don't listen to dremer
    Jun 2010
    I'm riding a 2008 specialized Enduro size large and I'm 5' 11".
    I was reading how to fit a bike but who knows if I'm doing it right. Says that if your sitting on the bike with pedals at 3 and 9 your first bone below the knee should be plumb with the pedal spindle. Then it also says that if you put your elbow on the tip of the seat your fingers should reach halfway up the stem.
    My fingers don't even reach the stem but my knees are forward of the whole pedal. My seatpost already has an off center style bracket that already gives me an inch setback.
    Is that just the shape of the frame that makes me sit that way. I honestly feel good on the bike but I do get sore knees and I'm slow as hell on this bike. Of course that could always be me not the bike.
    Reputation: wabiker3576's Avatar
    Jan 2005
    All of Truvativ's have a 25mm set back option
    TRUVATIV Stylo T20 Seatpost | SRAM a
    2013 Ellsworth Carbon Evolve XT
    2013 Ellsworth Enlightment XTR
    2013 Ellsworth Enlightment SS
    Bike Shop Employee
    Reputation: Shalom's Avatar
    Nov 2008
    I think he was referring more to a setback post with more than 25mm of setback. Generally, if that much setback is required, your frame is too small.
    The setback is just there to accommodate for longer femur length. Like stems, you can have too much.
    Nov 2008
    Sounds like maybe the geometry of the bike just does not work for you, sadly.
    I would take it in to get a proper bike fit and see what they can do. It will be money well spent.
    Jan 2005
    Go to Bikepedia it list almost all the seatpost just have to search thru it,
    BikePedia - Seatposts (With Integral Clamp)
    Bike Shop Employee
    Fat-tired Roadie
    Nov 2007
    For quite a lot of money, Rivendell can hook you up.
    Nitto Lugged seat post 27.2 x 250 - 11048
    As others have said, it's uncommon to need more than 25 mm of setback with a correctly fitted bike. I'm going to meddle and suggest that you reevaluate your fit. Here's an article I like.
    Start at the top, work through to the end, and be a little more conservative than he suggests about handlebar position if you ride off-road.
    How to Fit a Bicycle
    local trails rider
    Reputation: perttime's Avatar
    Aug 2005
    Quote Originally Posted by Shalom View Post
    Possibly but not necessarily.
    2 or 3 degrees of difference in seat tube angles changes me from straight to set-back posts, on frames that have perfect "Reach" for me.
    "it IS possible that you are faster or slower than anybody else who is having at least as much if not more or less fun"
    Cow Clicker
    Reputation: wmac's Avatar
    Not necessarily. If you think KOPS is important, then, maybe. But, there's a lot of controversy whether or not it matters. Some big guys showing a lot of post can use a set back post to get some weight over the back wheel. Some bikes, like the Bikes Direct bikes, are notorious for having a short top tube.
    No, YOU don't understand. You're making an ass of yourself for all of eternity.
    KOPS is not important. Theres of course a lot more variables to fit, but a seat stuffed way back or forward on the rails, and wanting even more room is a decent indicator that something might be funny. Of course nothing is set in stone, but out of the ordinary odd-ball bits do raise red flags.
    It sounds like he might just be trying to get a KOPS fit, which shouldnt be done. If it feels good, its good.
  1. light weight offset / layback seatpost?
    By freeriderB in forum Downhill - Freeride
    Last Post: 02-01-2012, 10:04 AM
  2. Offset/setback/layback seatpost options for XL 907?
    By Team Honeybadger in forum Fat bikes
    Last Post: 01-02-2012, 05:54 PM
  3. Difference between offset and zero offset seatpost
    By D3NN15M in forum Beginner's Corner
    Last Post: 06-28-2011, 07:39 PM
  4. racer X Seatpost? Layback or inline
    By the_pilot in forum Titus
    Last Post: 05-24-2011, 02:09 AM
Members who have read this thread: 7
