Results 1 to 6 of 6
    Apr 2014
    number dot number naming
    Hi,
    I'm on the market for a new MTB, and I see a lot of models with names having a number.number format, like xxxxx 7.0 or yyyyy 6.9
    Do these numbers mean anything?
    Reputation: Thyamine's Avatar
    Jul 2013
    Do you have an example or two you can show?
    2012 Specialized Carve Comp 29
    IMBA Member
    Team J3 :: http://www.ridej3.com
    Apr 2014
    Canyon Testsieger-Bikes direkt vom Hersteller | Canyon Direktvertrieb (press shop, select a model, see the submodels. Example: the Nerve AL 29)
    Rockrider VTT VTT CROSS COUNTRY - Les vélos - Vélos, Cyclisme - Decathlon
    Fat-tired Roadie
    Nov 2007
    Yeah. Trek sells a lot of bikes by frame and spec level. I think the first number is usually the frame and the second is usually the component spec. Higher is better.
    To keep things from making sense, a lot of companies assign lower numbers to their fancier-spec'ed bikes. So you still need to glance at the SRP or the fork or shifters or something.
    At least numbers are sequential, though. Specialized's naming scheme is consistent from bike to bike, but not necessarily intuitive.
    And both companies are morons about name recognition. Trek has a series of numbered mountain bikes that are roughly parallel to the named mountain bikes they used to sell with a Gary Fisher badge. Specialized has made the venerable Rockhopper into a low-end bike, added the "Carve" and renamed it the "Crave." And the Stumpjumper can be a XC race bike or a all-mountain bike, depending on whether you get the hardtail or full-suspension version. Dumb.
    I think for Canyon you should carefully evaluate the specs based on the price not number. Some of their low number models are very adequately spec'ed making the sizeable price increase to the higher number model poor value, imo. I'd go low and get an upgrade component or two at a good price from one of the German online parts sellers.
    Apr 2014
    Often the number before the dot is the "level" of the bike (higher numbers = better components), and the lower number is the model year. E.g. 8.1 would be from 2011 with better components than 6.1. See the website of the German manufacturer Bergamont for example.
