Results 1 to 11 of 11
    Jul 2013
    (noob) Thoughs on my bike
    Hello all my name is Tyler im 24 and currently live in the awesome Pacific NW Bellingham, WA which has trails every where. Galbraith Mt is only ten miles from my house. However I am a noob to the MTB world and don't know much about but bikes. But I am here to learn and love riding so far. I just bought a 05 diamondback Topanga comp on craigslist for 250 the bike is in very good condition (couldn't upload pics says the image is to big not to computer smart either). But anyway I just wanted to introduce my self and get some comments and thoughts on the bike
    Reputation: Danielrg_usa's Avatar
    Welcome to the addiction! Mountain biking is an awesome hobby and a great way to stay in shape. I don't know much about that bike as I am pretty new to the hobby but have fun and ride it till the wheels fall off. Then put them back on and do it over.
    Fat-tired Roadie
    Nov 2007
    Galbraith is a great place to ride.
    Looking at bikepedia, looks like you got yourself a cookie-cutter aluminum hardtail. Not that that's a bad thing - you should be able to ride pretty much every trail up there, although it will have a somewhat lower speed limit than a lot of the rigs you'll see other people riding.
    Really big tires and a lot of hours of riding will take you a long way.
    Jul 2013
    thank for the comments guys. yeah galbraith is awesome went a couple of days ago and got lost diffidently going to get a map before next time I go. Also was riding bike today and left crank arm came off I went to the lbs and got a crank arm screw and put it back on but it came off again what can I do or should do thank guys
    Fat-tired Roadie
    Nov 2007
    Can you post a picture of your crank? There are a few different standards, and depending on what you've got, how big a problem you have and what you need to do to fix it are going to vary.
    With some older cranks, the torque in the fastening bolt had to be really high. And some of the standards were prone to damage from riding loose. With some of the newer ones, it's a lot simpler and you may just need loc-tite. But I don't know what you have.
    Jul 2013
    ok here are some pics I hope this helps
    (noob) Thoughs on my bike-dsc02675.jpg(noob) Thoughs on my bike-dsc02676.jpg(noob) Thoughs on my bike-dsc02682.jpg(noob) Thoughs on my bike-dsc02678.jpg(noob) Thoughs on my bike-dsc02687.jpg
    Fat-tired Roadie
    Nov 2007
    From a little clicking around, the standard on your bike is Truvativ Power Spline. Here's a (more-or-less) applicable manual.
    http://www.bike-components.de/bedien...manual2005.pdf
    31 ft-lb is a lot of torque. So you may just not have bolted your crank arms on tightly enough. If you don't have a sense of how much 31 ft-lb is, see if you can borrow a torque wrench. If you continue to have problems, use the lightest loc-tite (blue?) on the bolt threads. Don't put it other places - sometimes people have a really hard time getting crank arms off, and sooner or later, you will kill your bottom bracket and want to replace it.
    I thought when I ran by them today, "That tyler98226 dude should really know about The HUB." They seem to suck at The Internet, although you can find some information online. But you can also call them.
    The HUB
    903 1/2 N State St, Bellingham, WA 98225
    Phone360) 255-2072
    Hope that helps.
    Rogue Exterminator
    Reputation: kjlued's Avatar
    I hate to tell you this but maybe it will help you when buying your next bike and save you a considerable amount of money.
    Listing Detail - Bicycle Blue Book
    Just stick it in granny and start grinding.
    Jul 2013
    ok thank Andrew don't know much about torque wrenches but after doing some research about it I guess just a standard 3/8" socket with an 8mm hex drive on it would work. correct me if im wrong. do I tighten the spindle, bottom bracket as well or just the crank arm on, and do I also need grease? thanks for all your help and info on the hub they are closed until Wednesday diffidently going to check it out
    Jul 2013
    would this work it is a 1/2 in tho Name:  w3001c.jpg
    Yes ,you could buy a 1/2 "drive socket or an adapter to 3/8" drive.
  1. Replies: 10
    Last Post: 02-21-2013, 08:03 PM
  2. Replies: 17
    Last Post: 10-13-2012, 12:42 PM
  3. 80mm Fork - Any thoughs for XC riding?
    By mrm1 in forum 29er Components
    Last Post: 06-07-2012, 09:34 PM
  4. Thoughs and Questions after my first Flat Pedal ride
    By Wish I Were Riding in forum General Discussion
    Last Post: 01-28-2012, 06:38 PM
  5. Noob bike shopping on a budget.....from a Noob.
    By SuperSlow35th in forum Beginner's Corner
    Last Post: 08-29-2011, 11:33 AM
