Results 1 to 8 of 8
    Dec 2012
    Noob/geek question - Slack HT + steep ST + short CST + LWB + road drops?
    After a year back in the saddle, I've had the following evolution of experiences:
    Bought a large DB Overdrive that is a little big, but increasingly manageable with experience. Developing general XC skill, but not very good on trails pushing AM. Had difficulty keeping front wheel down, so decided I needed longer chainstays. Meanwhile, I flipped the front stem down and have had almost no difficulty since.
    Built a Surly Ogre medium as an all weather, all surface travel rig with 2.4 X-Kings and Nimbus Dominator rims, fenders, rack, and panniers. To fit fenders, chainstays are maxed out. This bike is now a complete monster, capable of traveling anywhere flat that I have to go out of necessity, but has a hard time with climbing traction, is hard to steer in tight spots, and too frequently has toe overlap. And while I like to be macho about hauling the weight, it makes it much harder to maneuver.
    Inherited a Centurion road bike, 56cm. Very much liking the road bike layout for speed and efficiency, but the 25mm tires are a little anemic for the multi-surface, obstacle negotiating, on/off trail riding, etc that I am looking for in an all-rounder. Also not sure I want to go downhill at speed on a non-paved surface, or down a steep drop like a pair of steps.
    A cross bike sounds close to what I think I need, but I think, and that's the key - I THINK I want a slacker headtube for less snappy steering, less toe overlap, and more front end stability. I THINK I want aggressive posture with non-aggressive handling. Think MTB wheelbase with road top tube and road bars. Short chainstays and relatively generous BB drop. Like taking my Ogre, putting on 700x38s or 27.5s, taking the chainstays to shortest position (431mm), sliding my seat all the way to the front (say to approximate a 74-75 deg ST), pushing the front wheel forward just a tad, and pulling back the head angle and top tube just enough to fit road drops with a normal length stem, say 70deg or so. Thought of a Troll. Nashbar CX frame too. It's kind of looking like the angles of an XS 29er or 700C hybrid, but with the TT of a M/L.
    Is there a bike out there like this? It sounds like a drop bar AM bike with slightly forward seat angle. It sounds silly just saying it, so that is probably farther than I'm thinking. But maybe a step in that direction.
    Fat-tired Roadie
    Nov 2007
    Hop on some stock 'cross bikes and see what you think. There are also a couple bikes on the market addressing the monster-cross/gravel grinder idea out of the box. Salsa and Foundry both make something. I forget the names, but go to their web sites and I'm sure you can figure it out.
    Basically, don't try to reinvent the wheel until you check out the prior art. There are a number of mixed-surface bikes with drop bars already out.
    Fat-tired Roadie
    Nov 2007
    Ooh, also, see how big a tire you can fit in your Centurion. Those older bikes weren't as stingy about clearance as a lot of contemporary road bikes. You might be able to get the 38s you want in there.
    Reputation: dbhammercycle's Avatar
    Salsa Fargo, 29er drop bar offroad tourer.
    I don't know about availability, but Rawland Draakar or the dSogn is good if you want disc brakes, and they should be able to fit a smaller 29er or beefier 650b. The Sogn and rSogn have rim brake posts for 650b.
    Singular Cycles Gryphon.
    My neighbor had a Centurion LeMans, it didn't look like you could fit a beefier tire in there, but you don't know till you try.
    I don't know why,... it's just MUSS easier to pedal than the other ones.
    Dec 2012
    The main difference between most MX or 29er touring bikes and what I think I'm looking for is the head angle. None of them seem to offer much different from the Ogre, and what I think I'm looking for is a front wheel that's farther away, like an MTB, but with the longer stem of a road bike.
    I'm picturing a 420-430mm CST, 65-70mm BB drop, 74 deg ST, 570mm TT, 70 deg HT, and a 45mm fork offset. Basically grab the Nashbar CX frame by each axle and pull.
    That, or start with a 29er CX, pick one with short CST and slack HT, drop down to 700x38 wheels, (same BBD but lower BBH), and pick one with a road length TT. So basically the changes from stock (assuming it's rigid) would be drop bars and downsized wheels.
    Fat-tired Roadie
    Nov 2007
    Are you thinking more road style drop bars or dirt drops?
    Dec 2012
    Road drops for sure.
    Dec 2012
    Still thinking and looking. Current theory is that a Nashbar CX frame may be the best fit, due to a low BB and short chainstay, combined with a 70.5deg HT angle. I would then need to get a fork with generous offset to match the slack HT, as well as add a little bit to my wheelbase at the front (one of my supposed goals). Most forks seem to be in the 45mm offset range, but I would think I need 50-55mm. Salsa Vaya for the 50mm, but for 55mm it looks like I'd need a 29er fork (ie Fargo), which would start to tilt the whole frame back.
  1. Longer CS + steep HTA or Short CS + slack HTA?
    By maragzner in forum 29er Bikes
    Last Post: 09-16-2013, 06:44 AM
  2. short travel, slack, short chainstay FS
    By r1Gel in forum 29er Bikes
    Last Post: 07-24-2013, 08:33 PM
  3. Slack vs Steep...Where's the LOVE?
    By mayha in forum Knolly
    Last Post: 05-06-2013, 10:12 AM
  4. FTW Slack and Short Hardtail
    By Singletrack Pig in forum 29er Bikes
    Last Post: 03-12-2013, 08:55 AM
  5. Chilcotin -- Slack vs. Steep
    By dulyebr in forum Knolly
    Last Post: 07-24-2012, 06:20 AM
