1. The most important thing about buying a new
bike is to make sure it fits. The only way you'll know if the bike is right
for you is to size up the bike and make sure that the bike's geometry matches
your body's geometry. Ask questions and do some research.
2. If possible, try to find a shop that will
let you demo the bike on real dirt. Five minutes in a parking lot won't cut
it. You wouldn't buy a car without a real world test drive, and a bike should
be no different.
3. Don't belive the hype. Just because
your favorite rider or best friend rides a certain bike, that doesn't mean
that's the best one for you. Have an open mind and be realistic about your
needs and ability.
Newton Deda Stem on a XC Mountain bike
Hi
Bought a Newton Deda stem today got it for a bargain £30 my question is it strong enough for a xc mountain bike (gaint xtc 950) as it seems to be a road bike stem. I only do xc riding occasionally, mostly use my bike on the road.
thank you
craig
You sure its the right clamp size? Standard road is 25.8-26.0mm while mountain is 25.4mm. If you got oversize (31.8mm) then you'll be OK there since both mountain and road are the same size.
oops i bought the 26 and my old one measure 25.4 will that make that much diffrence it seems to be solid
Problem with putting a 25.4 bar in a 26.0 stem is that your not getting even clamping force all the way around the bar. The bar is only being clamped at two points, which is a crushing force...and not safe at all. You can try using a homemade shim from a soda can...this can even the clamping pressure...but use at your own risk
ok im an idiot what if i bought these http://www.ison-distribution.com/iso...?part=HBIDSHIR would it be safe
cheers
Yes
 Originally Posted by c3ham
Yes...that'll do just fine
- You may not post replies
- You may not edit your posts
Forum Rules
