Results 1 to 10 of 10
    Newbie Question (again)
    I just got my new bike (2005 rockhopper comp non-disc) and had a question about eventually upgrading to disc. I am not sure whether i want disc brakes at the moment, and the LBS didn't have a 2005 disc in my size.
    So if i wanted to upgrade to disc, does it make more sense for me to buy a wheelset or to buy rims and spokes? Which one is cheaper? Forgive me if this is a stupid question. I saw that you can buy a basic disc wheelset for under $100, and u can get a pair of deore hydro for under $100 as well
    I'll post some pics if there is interest......
    Full of holes
    Reputation: SwissBuster's Avatar
    Just brakes.
    From Specialized website, it seems your bike has disc-ready hubs already. It looks something like this:
    You'll only need to buy rotors and brake levers for a retrofit.
    Only you can answer the question if you want to upgrade or not. It depends largely on the type of riding (and weather conditions) you do.
    Freshly Fujified
    Reputation: Call_me_Clyde's Avatar
    It's NOT disc ready
    Here's a link from Specialized's USA web site that has the specs for the '05 Rockhopper Comp (non-disc model):
    http://www.specialized.com/bc/SBCBkM...keTab=techspec
    If it's a USA model, then it has Joytech hubs. I'm pretty sure these are not disc compatible. If it's a model other than USA, it could be that disc hubs were put on the bike.
    In any event, should you choose to go with discs, I'm going to say that the cost of buying the new hubs and spoeks and the labor to disassemble the old wheels and relace them with the new parts will probably exceeed the cost of a set of machine built wheels with Deore disc hubs. Check with your LBS and see what they say. If you can buy Deore hydro's as a set for under $100, that sounds like a decent option.
    I hope this info helps.
    Bob
    'If Wal-Mart sold parachutes, who would jump?' Frank Havnoonian (quoting his father) Drexel Hill Cyclery
    pronounced may-duh
    Reputation: Maida7's Avatar
    Apr 2005
    If your current hubs are non disc you will need to change them. Do you know how to tell?
    If you need to change the hubs I think getting a whole wheel will be cheaper. And when upgrading check out the avid cable discs. I hear they are not expensive and work great.
    Quote Originally Posted by Call_me_Clyde
    Bob
    Is it just me or the specialized website says that the fork is disc-only
    EDIT: What do you guys think of hayes sole disc brakes? They are oem only, but you can find 'em on ebay
    Quote Originally Posted by noobking314
    You'd be better off saving a few more dollars and getting a much better pair of hydraulic discs. Either that, or stick with BB7s from Avid.
    i think most usa specialized hardrock and rockhoppers are either disc or NO disc (not disc upgradable). they are not too nice to get u ready for disc like trek or gf. no idea why they do that.
    well you just have to upgrade the wheels right? i think my fork is disc-ready and that makes sense because otherwise specialized would have to order different forks
    Vaginatarian
    a ready made wheelset will be cheaper, unless you ride in wet conditions or downhill alot
    I'd stick with the brakes you've got, they are lighter, if adjusted right, stop you fine and you will save several hundred bucks
    local trails rider
    Reputation: perttime's Avatar
    Aug 2005
    Ride it as it is, unless you are wet and muddy all the time.
    Clean your rims and brakes after your rides, to keep the sand and mud from eating your rims and pads. (And, as you have your water, soap and brush out, you might as well flush most of the grit from the drive train and the rest of the bike too)
