newb question --> Cables
Printable View
  • 01-16-2013
    ThrillSeeker2
    okay i have a full sus bike, and i have a 29er hard tail i tried taking the handlebars, mechanical cables, brakes and shifters off it and putting them on my full sus bike i got the fork brakes to work but the shifters and rear brakes dont fit (if i hold the rear brake and push down on the suspension the brake let go) ((its hard to explain)) do i need hydrolic brakes, new cables, can hydrolic brakes replace the mechanical cables with the same brakes and shifters? Please help :confused:
  • 01-16-2013
    Larry_K
    For everything to run smoothly you should replace the cables & housing. One thing that's critical is to make sure you make perfect/near perfect cuts on the housing and also get the lengths right for your frame. If you make the runs too long or short you'll cause binding and will constantly have issues with shifting and braking (more so with shifting since many brake runs are full length now).
    Here's some info from the Park Tooks website: Park Tool Co. ParkTool Blog Cutting Cable Housing
    Hydraulic brake lines only work with hydraulic brakes. They normally ship as a complete set (lever, brake line, caliper & rotor). If you're using combo shifter/brake levers you'd have to upgrade your shifters to standalone units if you upgraded to hydrualic brakes since the levers will be seperate.
  • 01-17-2013
    ThrillSeeker2
    okay so i don't need hydraulic brakes for a full suspension bike i just need to get the cables "fitted" with the proper housing
  • 01-17-2013
    mjduct
    yup, good cables/housing works wonders! I prefer Jagwire ripcord.
    not the lightest, but the strongest! especially for cable actuated disc brakes!
  • 01-17-2013
    Wishful Tomcat
    Be sure to take into account the suspension sag; the shifter cable and housing will also have to be cut longer.
  • 01-17-2013
    robselina
    That almost sounds like you did something wonky with the cable routing so the cable tension is affected by the suspension travel. Got any photos of your progress?
  • 01-17-2013
    ThrillSeeker2
    yea i think i just need much longer cables, but ill post some pictures before the day is over
  • 01-17-2013
    ThrillSeeker2
  • 01-17-2013
    robselina
    OK. A few comments:
    1) The rear brake housing should go between the frame and the fork stanchion instead of around it, since as you can tell it will either need to be way longer or bind the way it's installed.
    2) Looks like the section of cable housing that goes to the rear brake caliper is too short and you have it jerry-rigged at the moment.
    No offense intended if I'm misreading the situation from the photos, but do you understand the theory of operation for the brake cables? The general idea is that the housing acts as a rigid tube that won't compress. It sits with one side against the brake lever and on the other against the caliper housing. This way, when you pull on the cable with the lever, this tension is transferred to the caliper, actuating the brake. The housing is compressed when tension is applied to the cable, giving you brake actuation.
    The simplest way to implement this is if the housing is single piece from the brake lever to the caliper. (Your front brake is done this way). However, your frame (and many others) allow the housing for the rear brake to be fixed to the frame and the cable to have free spans in between. In this case, the frame is providing the rigidity that would otherwise be supplied by the cable housing alone.
    Your photos give me the impression that you're using tension between the last cable routing hole on the frame and the caliper to get it to to actuate. That's why it releases pressure when you compress the suspension.
    The rear section of brake cable housing should sit against the caliper on one side and in a frame fitting on the other, probably on the top tube. It has to be the right length.
    Any of this making sense or am I barking up the wrong tree?
  • 01-17-2013
    ThrillSeeker2
    OK. A few comments:
    Haha i have a good understanding of what you mean im fairly new at this whole thing and im trying to ghetto rig the **** out of this thing, so basically i should take it to a shop and have the cables "extended?" or would i be better off just telling them to do everything. I mean im eager to learn how this stuff works, but im not sure i can put together a safe bike.
  • 01-17-2013
    Zuarte
    The reason your brakes don't work is exactly what Robselina said - the cable needs a rigid housing to push against when it's pulling the caliper against the rotor.
    You're going to need a longer brake cable housing for that rear length. In fact, it won't cost a whole lot to go down to your local bike shop and ask them for a length of brake cable and brake housing. They usually have coils of "standard", "no-brand", "non-fancy" (or whatever you call it) cables and housings in their service dept. Some people like the Jagwire stuff. I invested in a full set once for one of my bikes, and it didn't perform 5x better compared to it's cost. I couldn't justify its price. It's up to you.
    Get some cables and come back and follow along with this video. You should be up and running in no time.
    Replacing Brake Cables - YouTube
  • 01-17-2013
    robselina
    Zuarte has good advice if you want to try to finish the job.
    I would suggest taking the bike with you to the shop to buy the cables and housing. You can chat with them about it in person - most mechanics I know will give you advice on how to do the repair yourself if you're so inclined.
    You can decide then if it's something you're comfortable doing yourself or not.
  • 01-18-2013
    kapusta
    Good advice given so far in terms of what you did wrong, here.
    I second the recommendation for running Jagwire Ripcord cables/housing. Makes a HUGE difference with mech disc brakes. It will run you about $15 more, but totally worth it. Run full length housing.
    My last piece of advice is to put some effort into punctuating your sentences. Your post was painful and difficult to read.:madman: I know capitals are hard for the younger generation, but how about a period here and there?
  • 01-18-2013
    Ben.land101
    Ditto. Jagwire ripcord is awesome stuff. (tons of colors too)
  • 01-18-2013
    jtmartino
    If you're not sure you can put together a safe bike, don't do it. Seriously. Brakes are nothing to screw around with.
    Either take it to a shop or find a friend that knows what they are doing. And as Kapusta said, feel free to utilize punctuation in your posts.
  • 01-18-2013
    ThrillSeeker2
    Yea im sorry, I'm an english major and I just rush everything I do. I will be taking it to my local bike shop and hopefully will be purchasing Jag Wires. They carry an orange colored cord that will match my bike.
  • 01-18-2013
    cpfitness
    seriously, I dont understand how some people even ride a bike with the lack of knowledge. I don't say this to mean. You've got a beefy ass downhill bike of some sort judging by the fork on the front and the person operating it doesn't even know how to hook up brakes? did you even look at how your brakes were setup before you took them off?
  • 01-18-2013
    WishfulThinking
    This is a very good question.
    *snip*
    I'm with jtmartino on this one. Brakes, especially when you're actually carrying speed on the trail and need to stop, are one of the most important parts of your bike and not setting them up correctly is asking for disaster. Take a trip down to your LBS and have them do the job for you and ask if you can observe them as they do it. Chances are they'll let you hang around out of the way so you can at least get an idea of what to do. Yes, it'll cost money. But at least you'll have properly routed cables and pick up some useful (hopefully) knowledge along the way.
    If you don't have an understanding of the proper way to do something, don't.
  • 01-18-2013
    Zuarte
    I've come to learn that some people don't even know what they don't know. And you're right - it's a dangerous state to be in, but many people don't realize the gravity of what they're messing with. When I got my first longboard, I didn't know speed wobbles was a "thing" until I was tumbling down a hill. :madman:
    OP, what bike is that? It's hard to tell from the angles. You're installing mechanical disk brakes onto it as an upgrade? Was it an older dh bike that used rim brakes?
  • 01-18-2013
    kapusta
    Originally Posted by WishfulThinking View Post
    ThrillSeeker - You say you're an english major and just "rush" everything but that's a terrible excuse.
    [/B]
    I think he was just talking about typing.
  • 01-18-2013
    WishfulThinking
    Ah, yeah I see that now. My bad lol, I'll go ahead and edit that.
  • 01-18-2013
    ThrillSeeker2
    I'm sorry if I come off stupid and immature. My father bought me a downhill frame forks and wheels. Also since I try hard to relate to father and his biking so I thought I would try building this myself. I never said I was good at this biking thing. I don't know how all of this works. I thought I could rig cables from a 29er hardtail to this kona stinky(04) and the cables didn't fit so I thought I should ask some more expirenced bikers.
  • 01-18-2013
    robselina
    Dad nearby? Can he help you build it up? Could be a good bonding experience and you'd have a safer bike as a result of doing the work with someone with more bicycle maintenance experience.
  • 01-18-2013
    cpfitness
    Ahhh that explains a lot? Why not ask dad to help you build it?
    Sent from my DROID RAZR using Tapatalk 2
  • 01-18-2013
    ThrillSeeker2
    Because my father believes I'm not good at anythin. Therefore if I can show ow just a little bit of knowlegde towards bikes. It would.... ahh just forget it.
  • 01-18-2013
    robselina
    OK. Park Tool sponsor a series of community college courses that go through all the basics of bike maintenance. They typically last a couple of weekends and cost around $130-$150, but could be well worth it to build up your knowledge base.
    Park Tool Co. The Park Tool School
    Sounds like you're a student, why not see if such a class is available as an elective this semester? You'd learn a thing or two about how to do your project (and a bunch of other bike maintenance tasks) the right way.
    Then next time your dad brakes a chain on the trail you'll have it covered :thumbsup:
  • 01-18-2013
    jtmartino
    Dude, find a buddy who knows bikes. Surely someone you ride with knows how to wrench? If not, take your time and watch videos online.
    Better to be safe than sorry. Even a single improperly installed bolt could spell disaster for you.
  • 01-18-2013
    ThrillSeeker2
    Sorry I'm only getting into biking now. My dad bought me the stuff a few weeks ago
  • 01-18-2013
    cpfitness
    Im sincerely sorry to hear he thinks tjat way. I think you should call him out " hey dad, your right, im not good at much. Why dont you teach me?"
  • 01-18-2013
    ThrillSeeker2
    He would probably say, you made it to college right? You figure it out
  • 01-18-2013
    cpfitness
    Lol. Then say " **** you, pick the chamois out your ass"!!
  • 01-18-2013
    Zuarte
    What started out as a brakes issue has quickly grown into something else. I'm sorry your dad is the way he is, and I'm sure there's a long story either of you can tell. But it seems to me like you've arrived at a fork in the road. Is it really important to you that you do this yourself?
    If not, then just take it to a bike shop, have them fix it, and go on living your life.
    If it's for the larger purpose of showing that you can actually do something with your own hands, then we'll try to help as best we can.
    Which is it going to be?
    Btw, your dad bought you a downhill bike...that's pretty cool isn't it?
  • 01-18-2013
    cpfitness
    Yep i agree. And cycling is a great sport with a lot of.different disciplines, hopefully dad being a ****** hasnt totally turned you off to the sport.
  • 01-20-2013
    ThrillSeeker2
    I really would like do do it myself but the thing is i don't feel comfortable doing it with something that can be so devistation of done wrong, and I agree its cool, I thanked him several times, but even a conversation lasting more than 5 min about bikes would be more than worth it
  • 01-20-2013
    Zuarte
    I see you've got some heavy circumstances on your hands, but don't allow your self worth to be shut by others. You have to first prove what your capabilities are to yourself, and other people will see it in their own time.
    The good news is, you're working with cable disc brakes, which are the easiest of brakes to work with. You've already gotten the fronts working, right? Seems like your rears are just a cable housing away from working too.
    If doing it yourself means a lot to you, don't be afraid. Are brakes high consequence items? Sure. But use common sense. When we're testing out brakes after working on them, we don't go bombing down a hill to see if they work. We'll do it at low speed in the driveway, so we can catch anything wrong before the stakes get high. What's the most complicated thing you've done before? Not just bikes, but anything.
