Results 1 to 10 of 10
    Oct 2012
    Newb question about brakes
    I just assembled my first bike out of the box. Everything went pretty easy. The only question I have is about the hydraulic brakes. I can hear a slight rubbing noise without engaging the brakes. Is this normal or do I have to do an adjustment? I loosened then re-tightened the calipers, but nothing jumped out on what is causing the rubbing noise. Will it auto-adjust itself? Any suggestions? TIA.
    Reputation: Naturally Aspirated's Avatar
    When you loosened the calipers did you press the lever to get the caliper to center itself?
    YETI SB-66 CARBON
    SCOTT GAMBLER 720
    Oct 2012
    I didn't press any lever, but I just kind of moved the calipers slightly to make sure the rotor was as centered as possible.
    Try slightly loosening the screws that hold the caliper in place. Hold down the respective brake lever. Tighten screws. Release lever.
    YETI SB-66 CARBON
    SCOTT GAMBLER 720
    local trails rider
    Reputation: perttime's Avatar
    Aug 2005
    That usually works:
    Loosen calliper bolts, just enough that the calliper can move side-to-side
    Squeeze and hold brake lever
    Tighten the bolts
    Occasionally, I've had to adjust calliper position manually: loosen, push the way I think it should go, tighten - but that is pretty hit and miss, and may have to be repeated several times to get it just right.
    "it IS possible that you are faster or slower than anybody else who is having at least as much if not more or less fun"
    I like turtles
    Reputation: TiGeo's Avatar
    If you do this and you still get a little rub, it can be that the rotor is a little out of true..not a big deal. Just go ride it..sometime actually using the brakes for the first time helps out this issue.
    Geologist by trade...bicycle mechanic (former) by the grace of God!
    2018 Niner RKT 9 RDO - enduro are #@$%
    Jan 2009
    tighten each caliper bolt carefully and slowly, alternating bolts. sometimes tightening one of the bolts while the other is loose will cause the caliper to twist.
    Try making the adjustments mentioned by others, but first, put a business card between pad and rotor on each side. This will keep the brake centered and prevent the movement while tightening the bolts. You can achieve zero rubbing.
    Picture Unrelated
    Reputation: zebrahum's Avatar
    Jun 2005
    Good advice above, but take the bike out for a quick ride around the block to bed in the pads before you go pulling your hair out.
    Put on your helmet (this is important, I've seen the brake check go horribly wrong) and do a couple low speed test stops and if you're confident your brakes are working well, get up a little speed and do a firm brake using just the rear brake. Then repeat it a few times, you'll feel the brake get a little better at stopping each time. Repeat this with just the front brake (seriously, be careful not to go over the bars). Once you have the pads bedded in through this process go back and adjust per the above.
    Oct 2012
    Thanks for all the help. I'm gonna try all the suggestions until I get it right. I didn't want to ride it yet in case I may damage something. I'm hoping I can go for a quick ride since the weather right now is perfect.
  1. Newb question - tubes
    By RebornMountainBiker in forum All Mountain
    Last Post: 02-19-2013, 06:51 AM
  2. Newb needs new brakes...
    By HighSpeedChase in forum Brake Time
    Last Post: 09-23-2012, 07:42 PM
  3. Newb question...
    By mk.ultra in forum Beginner's Corner
    Last Post: 07-20-2012, 12:06 AM
  4. Newb question new derailer
    By egoptofit in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 11-06-2011, 07:43 PM
  5. Newb question about what to ride?
    By 1dkl1 in forum XC Racing and Training
    Last Post: 09-18-2011, 04:49 PM
