Results 1 to 6 of 6
    Newb - need to replace cassette, need help
    I'm replacing the cassette on the back tire or at least I would like to. I don't know how to select a new cassette. What do I need to look for?
    I just got new SRAM X7 shifters and front/back derailluers.
    I have a Shimano Alivio crank (FM-MC20)
    Thanks in advance.......
    ...idios...
    Reputation: SteveUK's Avatar
    Which cassette are you replacing and why are you replacing it? The only relevence the rest of your drivetrain has when you choose a new cassette is how many gears you need.
    The Shimano XT is generally considered the benchmark 9 speed cassette; it's strong, light and relatively inexspensive.
    Diogenes
    No good in rock gardens..
    Reputation: Sideknob's Avatar
    I'm assuming it's a 9 speed shifter set up? Each manufacturer makes a heirachy of cassesttes - the cheaper ones will be heavier and not have as nice a finish or nice shiny plating on it etc. They will still shift much the same, if the rest of the drivetrain (shifters, derailleur) is set up right.
    There are also slight differences in ratios - you can generally get 11-32 tooth options or 11-34. The more teeth the lower the gearing.
    Generally if you are replacing a cassette that's hada bit of use, you will need to replace the chain as well, as a worn chain may "skip" on the new cassette.
    Less isn't MOAR
    Jump in
    Reputation: Tebr73's Avatar
    Quote Originally Posted by Sideknob
    Don't forget the middle and/or granny chainrings. If they look like throwing stars they will cause your new chain to skip under pressure. The general result of this is an unfortunate meeting between your gentlemens and the stem.
    Quote Originally Posted by Tebr73
    Very good point.
    Less isn't MOAR
    pronounced may-duh
    Reputation: Maida7's Avatar
    Apr 2005
    I find the Shimano LX cassettes to be very high quality at a decent price. If you want to stay with all SRAM parts I suggest the 970. The more expensive ones can be a few grams lighter. The cheaper ones don't have as strong a finish.
    Why are you replacing it? Is it worn?
