1. The most important thing about buying a new
bike is to make sure it fits. The only way you'll know if the bike is right
for you is to size up the bike and make sure that the bike's geometry matches
your body's geometry. Ask questions and do some research.
2. If possible, try to find a shop that will
let you demo the bike on real dirt. Five minutes in a parking lot won't cut
it. You wouldn't buy a car without a real world test drive, and a bike should
be no different.
3. Don't belive the hype. Just because
your favorite rider or best friend rides a certain bike, that doesn't mean
that's the best one for you. Have an open mind and be realistic about your
needs and ability.
 Originally Posted by Rod
Oh wow, this thread is a complete mess. Where to start... don't order parts or frames before checking to make sure that is what you want. Post here before you order the parts. The frame may be too big or it may fit you great. Those size bars should be fine, especially since you already purchased them. I ride with bars that wide.
For all of you new people. Mimi has very valid points. You can put a bike together without a stand and tune cables, but a bike stand makes life a lot easier. The OP can hang two hooks in the ceiling of his garage or whatever, but a brick on a 5 gallon bucket. Really? I would not want to set a frame worth 2k on that and work on it. That is ghetto.
Yea I am most definitely going to get a decent 360° swivel bicycle stand. I found some good ones for around $120 I am interested in.....
 Originally Posted by MadScientist
T I had a few questions about brakes and gear sets and shifters. .. what is a good brake set up? Avid juicy ultimate carbon? I see the newer bikes run avid xo? Im not sure? I have a 9 speed sram xo rear derailleur and it is a long cage? A friend sold it to me for $30.... i would need 9 speed sram shifters for this correct? this should work right? Sorry for all the questions....
I'd suggest the shimano hydro brake. The new XT are very nice, but you can get much better deal with the older model which is still awesome. Juicy ultimate is not really that good, many(myself included) have issues with howling and vibration, the newer elixir cr was not better either, it came with my blur LTc.
SRAM xo are very nice they are 1:1 ratio vs shimano 2:1 rear shifting of course, the front are the same 1:1. Yes you'd need SRAM shifter, take your pick trigger or Gripshift.
What else do you plan to buy, next set of question should be fun wheels, forks, tires. Save some fund for a dropper post they are added fun for trail riding. What is your seatpost diameter 30.9 or 31.6?
Seat post diameter is 30.9..... I plan on running spinergy xyclone wheelset.....
Thanks again everyone.... I just figured the bars I purchased would be adequate for the situation... the bars are 640mm long... 31.8mm clamp.... 6 degree up sweep... and 8 degree back sweep.... low rise.... I had a few questions about brakes and gear sets and shifters. .. what is a good brake set up? Avid juicy ultimate carbon? I see the newer bikes run avid xo? Im not sure? I have a 9 speed sram xo rear derailleur and it is a long cage? A friend sold it to me for $30.... i would need 9 speed sram shifters for this correct? this should work right? Sorry for all the questions....
There is a sticky thread in the Drivetrain forum about which derailleur with which shifter. The Brakes forum has lots of good information about which brakes various people are having problems with. The long cage is usually safe for most MTB uses. Some people adjust their gear choices so they can use a medium cage and shorten the chain some. Not me.
Exact match shifters are certainly the best choice. Are you going to run a front derailleur as well?
Dam I fell asleep and people went bonks. Thanks fer backin me up cpfitness...
And thanks for the negative points mimi1885.... you shud be proud of how awesome you are AND how many posts those little fingers can push out.
OP, yes if you have the cash buy a repair stand. They are a great addition and you will use it forever! That being said, is a repair stand an absolute necessity? NO! Will it make life easier? Yes, especially when you get to dialing in your drive train. But I am sure many of you out there remember the days of just flipping your bike over on its seat and handlebars and working on it from there. Not ideal, but you can get the job done. OP, most of all, however you end up doing this build, have fun! You will no doubt be frustrated at times, but bikes aren't rocket science. Enjoy!
 Originally Posted by cpfitness
you are such an unknolwedgeable person it's disgusting! lol, I didn't know I needed to make a youtube video of me sliding a seatpost into a tube and locking it down with a clamp. or putting my wheels on and shutting the quickreleases. WHY ON GODS GREEN EARTH DO YOU NEED A STAND TO BUILD A BIKE? explain the role that a stand plays in building a bike? I wonder if you've even ever built a bike with the answers you are giving, they are so ridiculous. And the fact that it's carbon is irrelevant. people act like carbon magically implodes during assembly without a torque wrench. torque wrenches are for inexperienced dummies. Have you ever seen someone use a torque wrench to put lugnuts on a car wheel? technically the instructions call for it, but people that have experience and know what they are doing don't need to do it.
Wow. So much anger. Building a bike up with a stand is easier than without a stand. It's a lot easier to face a head tube and install a headset when a frame is in a stand. It's also a lot easier to face a BB shell.
Speaking of unknowledgeable, your instructions on installing a bb are off a little bit. You didn't cover press fitting.
Your torque wrench analogy is a bit off too. First, any pro wrench (auto, bike, motorcycle, etc) will have a torque wrench in their toolbox.
Second, your example of lug nuts is flat out wrong. A mechanic absolutely uses the proper torque when installing lug nuts. You're likely too ignorant to realize that they install them w an impact wrench. And the impact wrench has a specific torque setting on it.
The OP is spending a lot of money to build up a sweet bike. Money doesn't appear to be a limiter. So buying a nice stand, while not required will make the build easier and will be used whenever he's wrenching on his bike.
Take it easy, Francis.
Sent from my rotary phone and compiled with a telegraph machine.
JPark - 3.5- don't listen to dremer
Not anger at all, just passion and EMPHASIS. With the written word its difficult to always communicat the feel of what you are saying like what we can do in the spoken word so I use some caps from time to time. My dad was a mechanic, I was using impact wrenches when I was 5 years old. I can also tell you that with all of the different wheel types that the average shop isn't taking time to read manf specs and adjusting impact wrenches. it just aint happening. My dad had a SHITLOAD of torque wrenches in his toolbox. There were certain applications they would definately get used for but for run of the mill stuff they didn't come out of the box. Sorry, but I'm experienced, I don't need a torque wrench to install most parts on my bike though I may use it simply because one of my tool kits has a convenient set of hex bits to use with it.
As for money being a limiter, the op did state that he was trying to save a few dollars (to which we all informed him that building himself was NOT the way to do so) but If someone was trying to save money suggesting that they NEED to buy a stand is flat out silly!! An el cheap stand is probably still $50-75. The most difficult things to install for the inexperienced would be cranks and headsets, things that a LBS would charge $10-15 to do. IF you are looking to save money, have the shop install those, then put your wheelset on your bike and lean it up against something and bolt on the rest of your parts, it's really quite simple. I can't believe that this is even being debated!!!!!
Written communication is far more effective if you use paragraphs, not all caps (yelling).
I'm a little unclear on your point. It sounds like we're agreeing? That having a stand makes a bike build easier.
You seem to be struggling to read for context. The OP stated that a side benefit of the build up would be saving money, which was corrected by many here. But the reason for the build up was to learn how to build a bike, not paying someone to do it.
Installing a headset is really simple. You don't need to pay a shop to do it. It's a lot easier if you have a stand. A stand is something that you'll use as long as you're riding bikes. You don't need one, but it makes routine maintenance far easier.
And that was Mimi's point.
Cpfitness, I am gonna disagree a bit here. For the inexperienced I think adjusting front and rear der would be the most difficult and frustrating part of the build but still quick, cheap and easy at LBS. Yes, pressing cups should be done with the correct tools but not difficult. Correct spacing on the BB is imperative but most new BB come with very detailed instructions to become nearly a no-brainer. Also, Harbor Freight has torque wrenches for as little as $19.99...not the best but will do for the beginner.
What have you contributed to this post so far beside personally attacking mimi and suggest a backyard DIY crapper. Stop with the number of posts, mimi is a contributing member and the neg rep given to you is well deserved. If you are not comfortable being civil in this forum I'd suggest you go back to pinkbike.
Go back and read his first post, not only mimi did not shred op every said was true. If you want to build a bike get the stand and tools then go from there, it gets easier but there's a learning curve, even said that DIY stand is ok to most general work by experienced wrencher. What's wrong with that?
Not every noobs buy a two thousand dollars frame and want to build it up themselves, it can be done but not easy and certainly not with a crapper and misfit tools. Using the right tools is hard enough for noobs' first build and here you are goading op to do it with a poor suggestions, and got mad when people disagree, go figure.
Mojo: You must have missed that he was super helpful in his last post where he took what everyone else was saying and passed it off as if he had been the one saying it all along. Is that not helpful? I am glad you realized it was a crapper because I was super confused about what the bucket was for.
I agree that tuning deraileurs can take some work but i consider that tuning, not assembly of the bike. Yes adjusting on a stand is easier but again, flip your bike upside down and do what you gotta do or ride it on the block and tweak it which will let you see how its going to shift under load
Sent from my DROID RAZR using Tapatalk 2
I run the Avid Juicy Ultimate Carbon on my SJ and they work well. 203 front/185 rear Avid G2CS discs with metallic pads. The Avid Elixir series replaced the Juicys on the newer bikes.
Keep the X0 Rear derailleur unless you're going 10-spd. You'll need SRAM 9-speed shifters. X5 or better. I really recommend at least an X7 or X9 (metal thumb levers) for the shifters.
-S
I will echo others sentiments. Building from scratch and cost effective are two things that almost never go together. not to say that it can't be done, but it's awfully tough if you have no experience.
dont let the naysayers dissuade you. if you want to start riding right away, buying a used bike is a better option. if your willing to take time to get it built and buy it part by part, then go for it. There are also a lot of speciality tools specific to bikes, particularly in the area of crank removal and installation and headset removal and installation so you not only need to buy parts, you need to buy the proper tools or have a bike shop do certain aspects of your install
WHY ON GODS GREEN EARTH DO YOU NEED A STAND TO BUILD A BIKE? explain the role that a stand plays in building a bike? I wonder if you've even ever built a bike with the answers you are giving, they are so ridiculous. And the fact that it's carbon is irrelevant. people act like carbon magically implodes during assembly without a torque wrench. torque wrenches are for inexperienced dummies...technically the instructions call for it, but people that have experience and know what they are doing don't need to do it.
I guess u dont read, he already said he ordered it!
I dont want to get a bike off of craigslist.... I already have a great frame
I agree. cp Edumucation is out of this world, he's all over the map. Not only he's a self admitted clueless noob on the post he started in the forum however later in this thread he has become an expert bike builder. Even suggested op to buy a crappy bike from bd and transfer them to the new bike, what a noob move. Oh, flipping bike over to tune the drive train is just classic, cp you should stick with road riding and hybrids. I don't have the patience mimi has to be quite civil with him.
This is a noobs corners where good solid advices to noobs is needed and I think veterans like mimi, rod, ken as well as everyone except the 2 morons has painted a realistic pic for op. These 2 bring bad rep to noobs advising noobs.
I just ordered some avid 7 ultimate juicy carbon brakes f/r..... sram xo carbon shifters..... avid g3 clean sweep rotors 203/185 mm.... let the pile of parts begin
Yeah, bikes exolode when you rest them on the seat and handlebars, especially rugged mtbs. And i forgot, the xtr and x9 groupsets on bikes direct bikes are inferior to the ones on name brand bikes. Silly me. Im a moron. I havent built a dozen road bikes in the past 3 years and you know those mtb hex bolts are wayyyyy different than those road bike hex bolts. I dont know anything.
Nice!! I picked up a used set of Juicy Ult 7's recently for spare parts - I should just rebuild those calipers and have them handy. My wife isn't too happy with my ever growing parts pile. I think I have enough parts to put together another bike soon.
-S
Yeap, that the confirmation needed. When you see BD deals you just got tunnel vision and only see XTR, X9 components not all I might add, nevermind some come with road cassette, oem fork, god knows what wheelset, and generic headset that may not fit op's bike. To top them off without the bike stand he had to pay to take the parts off, in order to install it into his bike. If you are building a $300 road bike on the budget bike then it's one thing.
Looks to me like op is planing to build a $5000+ retail bike and the advice you have to offer him is lean it against the wall and flip the bike upside down to tune the drivetrain.
Lol I dont know about $5000... but I have $2500... I figure it will cost me that much to get a decent start and have some pics to post. This is actually fun and suspenseful waiting for parts... I am going to go to my lbs for install help if you tube cant help me.... I plan on buying a bike stand from my lbs so I am sure they will help... thanks again everyone.... this is getting addicting to say the least
Retail . Parts you picked so far were top of the line.
Sent from my iPhone 4s using Tapatalk
Obviously you aren't too familiar with Bikes Direct. Yes, there are some bikes that are a mish mosh of parts, particularly on the lower end of the spectrum, as you move your way up the chain, they have many offerings that are specced high end all around. He's already stated that he has a frame, FD, and Shock. For someone who has never built a bike before, removing the parts from a frame is one of the BEST ways you can start to learn. Now he has told us he is looking to do this for $2500. For $2500 he could get this bike from bikes direct SRAM XO, 2x10 Speed 29er Carbon Fiber Front Suspension Mountain Bikes - MTB - 2013 Windsor C29 Team29er | SRAM XX hardtail mountain bikes | Save up to 60% off list prices on new bicycles
Which has very solid all around set of components for him to START riding on. He then has a carbon frame and Reba Shock he can resell. Perhaps the market for a carbon BD frame isn't that high but put the price right and someone will grab it. So he can probably recoup $5-700 from selling those items off. With that money he can buy himself another set of wheels and/or upgrade any parts that came from BD that he feels are deficient. At the rate the op is going it sounds like he is shooting to go pretty high end and I think he is gonna have some unpleasant surprises in his wallet! The little things of bike building really add up. IT's easy to think about wheels, cranks, shifters and derailleurs. But the little things like Seatpost, Seatpost clamp, pedals, saddle, handlebar, stem, tires, etc can really start adding up into the cost of a build.
I'm still in awe that you guys feel the need to tell people that a stand is an absolute necessity. You guys are more bougie than roadies!!! I'm surprised any of you even wrench your own bikes!!!!
I'm done fighting with you guys.
OP, post up the costs of the things you are ordering and keep a running tab. it will be fun to see.
did you get the brakes from ebay or something without rotors? Avids rotors are priced crazy imho considering you can buy a bb7 road mechanical disc brake for $60 and it comes with a g3 rotor that would cost you $30 to buy standalone. Obviously you are going with larger rotors but ultimately,your brakes should come with rotors already, make sure you aren't buying twice!
OP that is a good set up so far. Should be fast. I don't think you should buy a 29er from bikes direct since there would be a ton of research to see if the parts would fit. And since specialized didn't make a carbon 29er stumpy in 09 I am guessing your frame is 26" so truly buying a 29er would be stupid. I am actually proud of you for doing a good job collecting parts despite cpfitness "help". I may have missed it if you have a front derailleur or not. Make sure you do research on the type of pull you need and the clamp size. I am still confused about the bucket. Can I get a picture of how you used a bucket and a brick to hold a bike?
That's a good on, honestly lol. you are one extreme couponing for mtb
- You may not post replies
- You may not edit your posts
Forum Rules
