Results 1 to 9 of 9
Thread: New to tubeless
    Jun 2013
    New to tubeless
    Set up my 29er tubeless, Mavic SLR wheels and Bontrager 29-4 team issue up front/ 29-4 expert out back. The front tire has held super nicely, but the rear tire seems to loose pressure every 2 days or so. Should I just add some Stans sealant?
    How much pressure and how long have they since conversion? If it's only a couple pounds don't worry about it. Just top off before riding. If its going flat then somethings wrong. I check for leaks by pumping the tire to around 35psi and spraying soapy water on it. It'll bubbly from where it's leaking so you can see where the problem is.
    Jun 2013
    I fill it to 30psi and the rear slowly drops in pressure. It went flat in 4 days. It's a new setup (less than a week old). I do notice my front tire is labeled tubeless, while my rear tire is not. I don't want to add Stans if not needed, but if that's the solution then I will. What's the solution? Thanks in advance.
    A non tubeless tire generally requires a double shot of Stan's, 4oz. If you can't find an obvious leak you can try adding 2oz of sealant and go from there. Have you been riding it? It seems that the best way to get Stan's to do its thing is by riding.
    Reputation: masterofnone's Avatar
    Adding stan's won't hurt, I always run sealant. Almost all my bikes are setup tubeless, losing air over the course of several days is no biggie. Unless it's a dedicated UST tire and rim combo some air loss is inevitable, don't read into it too much. A new tubeless setup will lose a little more quickly until it "settles in", I usually find they may even go flat the first night or two when new. Just pump it up, if the tire won't air up you'll have to investigate why the beads won't stay seated and start over.
    Jun 2013
    Filled it up to 30psi and took it for a long spin. It held just fine. I will keep an eye on it and refill if needed on my next ride. If it continues to need more air every few days, I'm going to add some Stans and hopefully that will take care of it. Thank you all for your help.
    I like turtles
    Reputation: TiGeo's Avatar
    I am confused; did you run Stan's or not? If not, and they are not UST, you need to run Stan's.
    Geologist by trade...bicycle mechanic (former) by the grace of God!
    2018 Niner RKT 9 RDO - enduro are #@$%
    Jun 2013
    Stans sealant was used. Rear apparently didn't seal as nicely as the front.
    I like turtles
    Then I concur with the soapy water treatment, try to find the spot that is leaking. I have had issue with the valve stem and the tape in the past.
  1. Replies: 4
    Last Post: 04-22-2013, 02:24 PM
  2. Replies: 2
    Last Post: 02-11-2013, 06:25 PM
  3. Running non-tubeless ready Racing Ralphs TUBELESS?
    By trumpus in forum Wheels and Tires
    Last Post: 02-07-2012, 11:28 AM
  4. Replies: 5
    Last Post: 01-29-2012, 08:42 PM
  5. Replies: 5
    Last Post: 02-15-2011, 12:30 PM
