Results 1 to 6 of 6
    New Fork Upgrade Need Help
    Recently my fork (Rockshox XC 28 TK) decided to break on me and Im unsure which of the following to upgrade to. Im not willing to spend over $150. I normally ride single track with a lot of rough/rocky terrain with jumps. Any help would be appreciated!
    Rockshox XC 30TK or Rockshox Recon Silver R
    Or any other fork in this price range with 100mm travel minimum.
    Enthusiast
    Reputation: JonathanGennick's Avatar
    I'd go the Recon just to get away from the very bottom level of Rockshox' lineup. The Recon stanchions are 32mm -- 2mm wider than those of the XC model. Otherwise, I don't see much to differentiate the two models in the specs on SRAM's website.
    Ive been told that the Recon Silver R has no compression damper though and could bottom out easily on "big hits" unless I buy and install a damper. Any truth to this or no?
    I just killed the xc 32tk that came on my merida 120, if you can stretch the budget get away from the xc range, im going all out to a sektor rl with the u turn 110-150mm
    Yeah I really want to get away from the XC. I think I can find the funds for the Recon Silver TK and just get that instead of getting the R and having to get a compression damper with it for another $40-50
    Thanks for your guys help!
    Single(Pivot)and Happy
    Reputation: Boulder Pilot's Avatar
    Compression is set at the factory. Rebound adjustment will slightly affect compression.
    The suspension of your bike sucks if it's different than mine. Really. It sucks. Big time.
