Results 1 to 10 of 10
    Apr 2013
    new fork, new wheels, or change hub
    bought a 20mm thru axle fork and 9mm qr wheels, crap.
    had no clue what a thru axle was until today, whats the best solution?
    new fork, new wheel, or just get a new hub for the wheel?
    turtles make me hot
    Reputation: NYrr496's Avatar
    What kind of hub is it? Is it convertible?
    I like turtles
    Apr 2013
    naw, its just a cheap set
    SixFifty: SIXFIFTY Mezzo Wheels with tires
    turtles make me hot
    I hate to be the bearer of bad news, but chances are, if you get a different hub, the flanges could be a different height and your spokes won't be the right length.
    If you get lucky and the flange height is the same as a Hope hub, you could swap in the Hope and convert it to any axle.
    I like turtles
    Jan 2013
    Quote Originally Posted by NYrr496 View Post
    I wish I had this info 2 years ago when I bought not compatible hub. Money wasted...
    Apr 2013
    damn, thanks, ill look for another wheelset
    What fork is it. You can get a different lower set for 125 or so for some forks.
    Your Best Friend
    Reputation: Silentfoe's Avatar
    Re: new fork, new wheels, or change hub
    Don't change the fork. Either get a new wheel or have your LBS build you a new wheel with an upgraded hub and spokes.
    I'm a mountain bike guide in southwest Utah
    Kitty! Kitty! Kitty!
    Reputation: GelatiCruiser's Avatar
    Oct 2012
    Why don't you sell one or the other and replace it with one that works? Or get new lowers for your fork.
    My advice is to buy a new wheel and make sure you use a hub that can convert easily between standards since most new forks have adopted the 15mm thru axel. I believe both Hopes and Chris Kings do.
  1. Wheels of change coming to the NPS?
    By zorg in forum California - Norcal
    Last Post: 07-16-2012, 06:48 AM
  2. How do Stiffer/lighter wheels change the ride?
    By pow77 in forum Wheels and Tires
    Last Post: 05-01-2012, 06:18 PM
  3. would you change stock xtc1 wheels for stan's?
    By 25lbs&counting in forum Giant
    Last Post: 08-23-2011, 06:30 PM
  4. Flash Carbon 3 owners: change the wheels out?
    By danK in forum Cannondale
    Last Post: 08-09-2011, 07:11 AM
  5. Should I change my DH wheels - Alex FR32
    By speedymadr6 in forum Wheels and Tires
    Last Post: 07-23-2011, 03:16 AM
