    Apr 2013
    New biker, new problem
    So got lost on a trail that was well above my skill level, and beat my bike up a little bit. After coming out of a tough section I noticed that on certain gears, there was something off with my crank set... what I mean is, normally if I stop pedaling the chain and gears stop moving and I can hear that universal gliding bicycle noise. But what happens to me now is the chain bunches up and makes a bunch of noise until something works loose, then it bunches up again and repeats the process, occasionally flinging the chain off the front gears. If I had to guess I'd say something in the rear gear set is jammed up and isn't spinning when it's supposed to. What do I need to do to fix this?
    Reputation: supersedona's Avatar
    Dec 2012
    First question,
    1. Is it fully clean and all plant/mud fibers removed? A simple grass or mud wrap on a gear can make a difference. If when it is clean and oiled, the problem persists advance to question 2.
    2. When spinning the crank, is the noise only in a couple gears or toward the high end or low end of each one? If it is the hi-low it can be adjusted with the adjusting barrel on the shifter at both ends of the cable(typically). Small adjustments at a time, then test. If those do not do it, let me know and we will go from there.
    '93 Giant Sedona ATX custom
    '93 Giant Sedona AtX aero-edition
    '73 Schwinn Suburban
    '95 Fuji Suncrest
    May 2013
    sounds to me like the cassette freewheel is catching.
    if you take the rear wheel off the bike, can you spin the gear cluster (cassette) with ease or does it stick and feel lumpy?
    Apr 2013
    I took a look at the bike this morning, and you guys had the right idea. I cleaned and lubed the rear cassette and was unable to reproduce the problem. With my luck it'll reoccur 5 miles out in the jungle haha
  1. AM Classic Race problem or schwalbe problem
    By jasonub in forum Wheels and Tires
    Last Post: 03-14-2013, 01:11 PM
  2. Replies: 23
    Last Post: 03-09-2012, 01:29 PM
  3. mt xc biker
    By thortiz in forum XC Racing and Training
    Last Post: 11-02-2011, 12:16 AM
  4. Colorado vacation plans for biker and non-biker
    By BmoreKen in forum Colorado - Front Range
    Last Post: 08-23-2011, 08:49 AM
  5. Weird brake problem (problem found)
    By B.BL in forum Brake Time
    Last Post: 05-30-2011, 02:11 AM
