Results 1 to 5 of 5
    May 2013
    new bike - tire rubbing on brake
    I got my Airborne in today. Slapped it all together, and found the front tire has a slight rub for about 60% of the rotation. I can either run the bike to my LBS and have them true the wheel, or I can try and and make some tweaks to the truing. This being my first time with disk brakes, it seems like it might be tricky since I don't have a good visual. Any advice would be helpful.
    Total Goober
    Is the tire rubbing, or the rotor?
    Quote Originally Posted by Fuglio View Post
    You guys suck im all bummed now
    May 2013
    rotor.
    B A N N E D
    If your rotor is rubbing on the pads then the disc brake caliper might need realigning.
    If your rotor isn't true then you will need to true it.
    Are you sure the front wheel is straight in the drop outs? Don't know how many times I've chased problems and then found the wheel wasn't fully seated.
    Try aligning the caliper first. On most setups, loosen the caliper mounting bolts, squeeze the lever and re-tighten the caliper bolts. Details on this at:
    Park Tool Co. ParkTool Blog
  1. XX brake rubbing
    By Cool_Man in forum Brake Time
    Last Post: 08-26-2011, 05:51 AM
  2. Help! Brake Rubbing problems
    By Specialized03 in forum Beginner's Corner
    Last Post: 08-03-2011, 01:43 PM
  3. Yup, another brake rubbing thread...
    By mtblucas in forum Brake Time
    Last Post: 05-31-2011, 11:53 AM
  4. Brake rubbing question
    By OS cuda' in forum Brake Time
    Last Post: 04-29-2011, 09:54 AM
  5. 2011 XT Brake Pad Pin Rubbing
    By half_man_half_scab in forum Shimano
    Last Post: 04-03-2011, 08:33 PM
