Results 1 to 16 of 16
    New bike problem
    Went for my first ride on my new bike. At the top of a small turn I have to make a sharp turn. The tire hits my shoe. This happened three times. Is this the way bikes are made now? Or is this a faulty bike. Seems very dangerous to me. But I know nothing about bikes
    You must got some long a$s feet........nah im kidding and i dont have an answer for ya question its just funny im picturing it in my head sorry bro
    T.W.O.
    Reputation: mimi1885's Avatar
    Your bike may be too small for you or you are placing your feet too far to the middle of the pedals. The sweet spot should be about the ball of your feet. In general you should not get toe overlap.
    Quote Originally Posted by Reice05 View Post
    I thought someone would say that & I still laughed.
    Quote Originally Posted by mimi1885 View Post
    your bike may be too small for you or you are placing your feet too far to the middle of the pedals. The sweet spot should be about the ball of your feet. In general you should not get toe overlap.
    +1.
    2009 Access 9.5 29er
    2010 Diamondback Insight RS (700c hybrid)
    Velorazzo frame build (26)
    icalebkim
    Guest
    Perhaps you have got too large feet, and need smaller cranks.
    That doesn't sound right.
    I measured the distance from the pedal to the tire on a turn. One inch, one inch is not much. That is not counting your shoe being over the pedal.
    T.W.O.
    Quote Originally Posted by Troutman View Post
    Ok now one inch that does not sound right. Do you mind sharing the size of your bike, tires, length of the crankset and the kind of pedal you use as well as your height?
    This the pic of my wife 13" Soulcraft with 26" tires, there's nowhere near 1",
    This is my BLTC it's not even close.
    Somethings wrong with your situation. Is the fork install backward? Don't laugh I've seen quite a few is not even funny.
    Mimi1885 I will get the info after work tomorrow and post it. Thanks
    icalebkim
    Guest
    Just saying, you've got a lot of bikes that look sooper cool.
    Jul 2003
    Troutman, I'll be interested to see the specs on your bike. This isn't a common problem with 26" bikes, but is not that uncommon with smaller framed or poorly designed 29ers. In some cases shorter cranks MIGHT help, but in your case it's hard to say. The spread of commonly available crank sizes only runs from 165 to 180mm, a difference of only 15mm or .6". Anyway, make, model, tire size, etc. would be helpful. A pic of the bike would be even better.
    Good Dirt
    Biking in clown shoes has always been regarded as a no-no.
    I figured out what was wrong. Very embarrassed to say, I had the fork on backwards.
    yep that'll do it.
    T.W.O.
    Like I said it's common enough
    OK, so you aren't the first person on this forum to have the issue. You're not going to be the last... The question is, who assembled your bike? You or a dealer?
  1. New Bike, New Problem
    By amysolamey in forum Beginner's Corner
    Last Post: 05-26-2011, 08:08 AM
  2. problem with my bike
    By nauc in forum General Discussion
    Last Post: 09-06-2010, 06:25 AM
  3. New Bike Problem
    By Fritobandito in forum Downhill - Freeride
    Last Post: 03-29-2010, 03:47 PM
  4. Problem with mtn. bike fit
    By Tucker in forum Beginner's Corner
    Last Post: 06-24-2009, 10:55 AM
  5. big problem with my new bike
    By ijason in forum Specialized
    Last Post: 04-30-2009, 12:06 PM
