Results 1 to 10 of 10
    Apr 2013
    new bike, break not working
    Have a brand new Norco Fluid 6.3 here, within a few mins of getting it home and riding it I lost my rear break(hydraulic). Has a lot of pull and no stopping power. Any ideas?
    Reputation: MSU Alum's Avatar
    Needs to be bled?
    Take it back to the shop ,they should fix it for free. How did you get the bike home? If you took the wheel off and pulled or bumped the lever that could cause the loss of brake. You could try pulling the lever quickly a few times to see itf it will build pressure.
    Jan 2009
    does the lever pull all the way to the grip with no pad contact? or do the pads hit the rotor and just slip?
    Nov 2008
    I know it's a long shot, but are the brakes pads still in the caliper? Hah..came across a rider on the trail about a year ago who swore his shop forgot to put back the retaining c-clip into the pad bolt...and he was scavenging the trails for his lost pads. Ive heard of shops doing a lot of odd things.
    Chances are you just have an air pocket inside the lines...or even could have sliced a line while riding and lost fluid. Double check all your brake lines and calipers and make sure it looks correct first. Then you should bring it back to the shop. If there is no "crash" damage They should fix it at no cost.
    Apr 2013
    Quote Originally Posted by mack_turtle View Post
    Yes all the way back to the grip.
    Would take it to the shop but I bought it 3 hours from my hometown which was the closest dealer.
    Quote Originally Posted by letsbuildasnowman View Post
    Yep, it needs to be rebleed. Since it's brand new, ask/demand for a rebleed or exchange.
    (づ ̄ ≥ ̄)づ
    Jan 2009
    the bike shop should do this for you free of charge. if it's a brand new bike, it's not necessarily the shop's fault. they probably did not touch the brakes, nor should they have touched them. the manufacturer sets up the brake and should be 100% ready to go out of the box.
    wait, I see the problem. that bike comes with Avid hydraulic brakes? you better start saving your gas money, or buy a bleed kit and learn to work on them yourself, because you are going to spend a lot of time getting those Elixer 1's to work. I have lost count on how many I have sent back to Avid under warranty. ask if the bikeshop will take them back and give you a deal on some Shimao Deore or SLX brakes.
    BlueSky has SLX for 80 a set. Order now and ride happy.
    Jan 2013
    I had the same issue...
    I had the same issue with my exiler 1's on my 2013 carve. I don't have the link but there is a recall on some elixer 1's. There is an O'ring that is under sized that has to be replaced. Got new elixer 1's front and back on my bike now under warranty and it's been no issues since.
  1. Replies: 72
    Last Post: 10-09-2017, 11:02 PM
  2. Replies: 12
    Last Post: 04-05-2013, 01:45 PM
  3. Replies: 5
    Last Post: 09-04-2012, 09:32 AM
  4. Replies: 2
    Last Post: 03-08-2012, 10:08 PM
  5. Bike shop break in.
    By bjornolson in forum Alaska
    Last Post: 09-21-2011, 06:11 PM
