Results 1 to 8 of 8
    New bike, bent wheel, now what?
    Ok, so I just got my first bike yesterday, a Cannondale F7 disk. They local shop my friend works at just got an XL in, and he put it together for me to try out. I liked it, and he got me a deal, so I got it. Great. Well, we went out riding last night, and I tried to go over a jump. I wiped out on the landing, and bent the back wheel. My friend and his coworker tried to true it up today, but they couldn't get it. It's rideable, but the back wheel is definitely not quite round anymore.
    Anyway, the F7 doesn't come with the greatest of components. I bought it because it seemed to fit nicely, and I was told it was a good frame to upgrade in the future. My dilemna is whether I should just get another WTB wheel to replace my bent one, or if I should go ahead and start upgrading now...
    If I upgrade, should I just get the wheel? Or should I go all out and replace everything in the rear while I'm at it? Any help would be great.
    That's an XC type bike. I don't know what kind of jumps you're doing, but It's not designed for much. Looks like those are the least expensive rims WTB makes...
    Review: http://www.mtbr.com/cat/tires-and-wh...92_139crx.aspx
    I know the website says it has dx23 rims, but it actually has sx24's. Although I doubt that it matters, the 24's are probably not any better.
    So if I'm upgrading the wheels, what would be a decent step up in durability without being really expensive? I'll probably just read a bunch of reviews and see if I can figure something out myself...
    Mavic 317s
    Vaginatarian
    do your friend and his co worker know how to true up a wheel?
    if not , take it to someone who does, they may be able to get it right, also have them check all the spokes and make sure they are uniform and tight
    most low end wheelsets arent really adjusted properly and loose spokes will make the wheel weak.
    you might be able to save yourself some dough and get stronger wheels to boot
    Buy a new (stronger) rim if it's bad and have your shop build it up. Get a freeride rim if you're going to continue to jump on that bike.
    Reputation: HardRockCop's Avatar
    Make sure it's a dual walled rim at least.
    don't move for trees
    Reputation: BKnight's Avatar
    Mar 2005
    go for the upgrade. flimsy wheels are sketchy to ride with and will hinder your growth in riding. you can keep your old hub and just get a new rim. If you go this route you will need to get new spokes and nipples according to the new rim. the mavics are a good choice, read reviews and see what is around. If you're looking for something stronger, consider an All Mountian rim for in the back, little heavier, but can with stand more abuse
    "Get a bicycle.You will not regret it if you live." Mark Twain
