Results 1 to 7 of 7
    Need to upgrade nice body, help!
    I have mountain biked once in my lifetime and that was with a friends bike. I have had my bike, a GT Outpost, for a long time. I want to get into bike riding, but there are some problems. I feel the body of this bike is great, strong as hell....but the front suspension is really loose (gives to bumps easily) and my gears are a bit messed up (skips gear or something?) at 2 specific spots. I also want to do a bit of urban riding, but want to be able to ride on the mountain also.
    So my questions are....What kind of suspension am I looking for? I am completely new to this stuff, and I will research, but if you can start me off I would appreciate it. As in what specs etc.....Can the gears be fixed? Or should I just buy new ones and? Is it easy to maintain a bike ? (I want to be able to do all the fixing up on my own) And are there special tires that are a cross between road and mountain?
    I appreciate the feedback
    Oh Yeah!
    I also only want to put in max $200 to upgrades!
    bi-winning
    Reputation: rkj__'s Avatar
    Quote Originally Posted by ttryi
    for starters, what you call the "body" of the bike is more correctly referred to as the frame.
    but the front suspension is really loose (gives to bumps easily).
    How heavy are you? What fork to you have now, is it an RST (low end)?
    To stay within your budget, your options for a fork will be limited. Take a look at what you can pick up on eBay used. Anyways, you will want something with about 80mm (3") travel, that is geared for an XC (cross country) bike. 100mm would definitely be the max you would want. You don't want to turn you bike into a chopper.[/QUOTE]
    There are several factors that could be causing this. Is there any chance that it is worn out? How much have you ridden the bike? Another possibility is that the rear derailleur is not indexed properly. This can me adjusted by turning the barrel adjuster. That is the small part where the cable enters the rear shifter. Here is a helpful link for adjusting your drivetrain.
    http://parktool.com/repair/byregion.asp?catid=53
    You may be interested in some semi-slicks. They are pretty smooth down the centre so they roll fast, but they have tread on the sides for traction when cornering. Here's an example:
    Hopefully some of this was helpful to you.
    thanks!
    thank you, that was very helpful. I do not know what suspension/fork is ont he bike, but i assume really cheap. I am 6 foot, 170 lbs.
    I will probably just take the bike to the shop for now to fix the gears...I will learn as I go. This post just goes to show how much I have to learn. Thanks!
    bi-winning
    That is probably a good idea. Make sure you get them to explain what is wrong and how to fix it, so that you can learn. Some shops may even let you watch them as they work.
    Reputation: Moroskim's Avatar
    Here is the rig I am trying to set up:
    -xt 761 front/rear drlrs
    -lx crank
    -shimano mega range 34 tooth caset
    -Avid Ball Bearing Seven Disc Brake '06
    -Shimano Alivio ST-MC20 8SP Shifter/Bl
    -:Easton EA70 MTN Seatpost '07
    - FSA OS-150/ 90 Degree Stem
    -Rock Shox Tora 318 Coil U-Turn Fork '07
    - Shimano XT Disc/Rhyno Lite XL Wheelset
    -FSA xc 190 handle bars.
    Any advice recomendations?
    Reputation: nachomc's Avatar
    Need to upgrade nice body!
    I read this thread title when my wife was sitting next to me and I got slapped
    :wq
