Results 1 to 6 of 6
    Oct 2013
    Idea! Need suggestion for new front and rear derailers
    Look for some pointers and suggestions!
    Reputation: JasonC71's Avatar
    Sep 2013
    What kind of bike do you have now? What derailleurs are you looking to replace?
    Oct 2013
    it's a downhill mountain bike no branding from when i bought it i am looking for front and rear derailers the one on the bike are shot.
    Moderator Moderator
    You'll need to post some pictures. It's impossible to answer your question with the amount of info you gave. Also, if it's a downhill bike, it wouldn't have a front derailleur.
    Oct 2013
    I don't know honestly i will post some pics in a few.
    Reputation: traffic002's Avatar
    Dec 2008
    Derailleur shot? What does that mean? What are you experiencing?
    Chain not staying in cog? Not shifting at all or it's shifting vaguely?
    Many times, if you buy a used bike, bad shifting can be attributed to old cable housing. Over time, grit can get in there and the cables don't slide back and forth smoothly. This can hinder when you go from larger cog to smaller cog.
    Another reason why you might be able to dial in the rear derailleur is if the hanger is bent.
    I would check these before buying a new set of derailleurs. Plus, your shifters have more impact on the way it shifts AND you have to match the actuation ratios.
    Just get out and ride!
  1. Shimano plus rear derailers
    By stygz1 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 11-11-2012, 07:39 PM
  2. New front rim suggestion needed - 29er
    By flatlandersk in forum 29er Components
    Last Post: 10-23-2012, 03:59 PM
  3. Info on Front Derailers that fit Jet9 bikes
    By bt in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-18-2012, 07:31 PM
  4. Front Tire suggestion: Replacing Purgatory 2.2
    By metelhead in forum 29er Bikes
    Last Post: 01-05-2012, 06:10 PM
  5. Cheap and light front hub suggestion
    By rob_co2 in forum Weight Weenies
    Last Post: 05-08-2011, 04:36 PM
