FAT BIKES
WINTER APPAREL
TRAINERS
    Dec 2011
    Need spacer adaptor for Shimano Hydraulic disk brakes
    I am replacing my Avid BB5 brakes with Shimano Deore Hydraulic brakes. I have 180mm rotors and I have a Rock Shox Reba shock with post mounts (see pic, sorry it is dark). Right now I have about a 20mm space between the caliper and the rotor. What type of adaptor/spacer do I need for this. Also, I have the same problem on the back caliper (about 20 mm gap).
    Thanks,
    Tim
    Attached Thumbnails Attached Thumbnails Need spacer adaptor for Shimano Hydraulic disk brakes-brakes.jpg
    Reputation: Misterg's Avatar
    Jul 2014
    Quote Originally Posted by tjrtmaster View Post
    I would imagine you would get a better response in the 'Brake Time' section of the forum, but anyway:
    The frame & fork mounts are commonly* designed to take a 160mm rotor front / 140mm rear, so anything other than this needs the appropriate adaptor.
    I think you need a +20mm post mount adaptor at the front:
    Need spacer adaptor for Shimano Hydraulic disk brakes-avid_acc_cpsmntbracket_postmnt_20mm_lrg.jpg
    There may be one on your old caliper if you haven't changed rotor size, but IIRC the BB5s might be packed out with a stack of washers.
    The same type should also work on the rear if is also post mount, otherwise you would likely need a +20mm IS adaptor:
    These are widely available once you know what you need
    *-Check the specifics for your bike, but from what you describe, this would be the case.
    Are you changing the size of the rotors? If not, the adapters on your Avid brakes should work for the Shimano.
    B A N N E D
    If you reuse the Avid adapters, do not put the cup (CPS) washers between the Shimano brake and the adapter.
    Shimano fork adapter: http://si.shimano.com/php/download.p...0A-001-ENG.pdf
  1. Alfine Drop bars with Hydraulic Disk brakes
    By fyford in forum Brake Time
    Last Post: 03-28-2014, 04:55 PM
  2. Replies: 174
    Last Post: 02-22-2014, 10:52 PM
  3. Best budget hydraulic disk brakes, not Avid.
    By nOOky in forum Brake Time
    Last Post: 06-10-2013, 03:57 PM
  4. Adjusting Shimano M445 hydraulic disk brake lever reach
    By User2 in forum General Discussion
    Last Post: 06-07-2013, 06:38 AM
  5. Hydraulic Disk Brakes
    By CannondaleF9 in forum 29er Components
    Last Post: 03-13-2013, 06:08 PM
Follow MTBR on Facebook
