• 11-01-2012
    Radamus
    Need some help building my first MB
    Howdy, I thought I'd bounce some ideas of those who would be willing to lend me some advice building up a bike.
    I bought this frame several years ago (Jamis Dakar) with the intent of building my own suspended MB. I had some knee injuries and other problems associated with plain ole getting old. I was riding my buddies rigid one afternoon and paid with it for three days barely able to walk. It's been several years, but I've bounced back and am ready to try this again.
    So, as usual, this is not an unlimited budget but I will spend what it takes for my goals. First off, I think this is a decent frame to start with? either way, it is what it is. Hey, it's going to be a casual rider but I grew up on dirt bikes, raced into my mid 30's but last broken leg wife said hang it up which I did. So my thrill seeking is probably more aggressive than most.
    So, that's the skinny. So I've been studying components and have some real 101 type questions.
    On a fork stem, isn't it threaded for top bearing? I see non threaded or clamp mentioned? My objective is, if I buy a fork, are they universal where they fit anything?
    Also, on bottom bracket, is this another item that fits everything? I think I have a fairly common production frame to work with.
    FWIW, when I bought this bike, first thing I did was dissasemble all the parts that bolted together. I was surprised by the tolerances and fit. It's a really tight bike that I think was barely ridden. So I lubricated it and assembled it and it has sat since, prolly 5 years.
    So, what I need, suspension fork, Geez, the list is endless but I know what I don't what, just some spring loaded sliding tubes, that's an insult to an old dirt biker like me.
    So I see all kinds of lengths, 100mm 120mm 150mm adj travel. I don't need 14" of travel, I know that just kills energy. What fits right?
    I think, but not sure, the Dakar came with Shimano Deore driveline` That should be decent isn't it?
    Disc brakes, is there a decent complete kit a noob could get that's trouble free and of decent quality? Wont see big downhills, we don't have hills here- flat as a pan here.
    Well, that's kind of the big stuff I suppose. Thanks for any help guys!
  • 11-01-2012
    Zoke2
    "On a fork stem, isn't it threaded for top bearing? I see non threaded or clamp mentioned? My objective is, if I buy a fork, are they universal where they fit anything? "
    no it is not threaded, you need an 1 1/8" stem to either a 25.4mm or 31.8mm handlebar clamp
    most new BB are external bearing and will fit both a 68 or 73mm BB shell
    for the fork you will need to know what travel fork the frame was designed for and it looks like that frame uses a 100mm travel fork
    for disc brakes you have a choice of mechs or hydraulics .. the Avid BB7 is the good mechs available
    the Deore drivetrain will fit and work on that frame and the next step up would be the SLX line
    hope this helps
  • 11-01-2012
    AndrwSwitch
    Do you only have the frame right now? Probably your best bet for not overspending on the basis of the build is either a build kit - a few sites have them - or a complete bike to cannibalize. To start with, I think pricepoint.com usually has build kits. But check out some of the other sites too - jensonusa.com, performancebike.com.
    Do you at least have the rear shock?
    What's the year on your frame? What kind of brake mounts? Are you confident it's the right size for you? (Hate to ask, but people sometimes buy some pretty random stuff.)
    The bike industry loves to "break" standards. There are a few bottom brackets out there. If your frame is 68 or 73 mm English-threaded, most external bottom brackets (and cartridge bottom brackets) will fit. But make sure to read the specs. Generally, you'd choose the crank first, but now that there's some extra standards floating around, you need to make sure it's for a standard that's compatible with your frame.
    Moving on, knees are kind of tricky. I messed mine up a pretty long time ago and lived with it for a while, before slowing way down and spending some time on rehab in 2007. While still imperfect, I can do a lot more than I could. Cycling is a good exercise in that it's very low-impact, but there are still all sorts of ways it can be hard on a rider's knees. Poor pedaling technique, often related to bad bike fit, is one of the big ones. I don't want to dissuade you from getting into cycling. It's certainly one of the better sports for someone dealing with knee problems. But you need to be careful, and you need to do it right.
    Here's a writeup from a site I like.
    Bicycling and Pain
    This is also a good conversation to have with your physical therapist or a sports doc. It costs money, but pain sucks and if you do a job requiring you to be on your feet, lost work is expensive too.
  • 11-02-2012
    cobba
    There's been all sorts of Dakar models over the years with forks that have travel ranging from 60mm up to 180mm
    Look on the following link and find a bike with a frame that matches the one you have, look at the specs for it and get a fork with a similar amount of travel.
    http://www.bikepedia.com/Search.aspx?Q=Jamis%20Dakar#
  • 11-02-2012
    jrogs
    I prefer hydraulic disc brakes over mechanical. Shimano deore are relatively reasonably priced and have good reviews. They are on my gf bike and do a good job. I think the thing to watch out or with your bike and buying a fork is make sure it is not tapered or it won't fit. This site is great for product reviews also. So check that out before you buy stuff. eBay also has complete drivetrains or sale a lot at a reasonable price. I have ordered them twice. The problem is it takes a while since they come from Hong Kong.
  • 11-02-2012
    Radamus
    Thanks for the reples!
    Cobba- nice link. Well, I still can't tell what year it is but I can tell you a little more about what I do have.
    This is a complete frame as far as frame/rear suspension. It has a Fox Vanilla coil over and I got a couple different springs with it. I do know when I bought it, and I don't remember the size, but it was sized for me. I did a lot of reading up on here at the time trying to find something decent to build and followed some advice I was given then and I did talk to the original owner back then about the size issue. I bought it from a member on here at the time.
    Bottom bracket- OK, I got the rule out and figured out that when you say 68 or 73, it's the width- this is 68mm. Hole for the headstock is 1 5/16" roughly.
    Frame is two tone black/yellow and says "sport series" on it, pretty sharp really. but I kind of assumed the models were seperated by the components used to build the production model, sound right? It looks the same as what they make today pretty much, at least what I can tell from pictures. It did have disc brakes, at least on the back, I can tell it was bolted up and the plugs for the rim brake mounts were never removed.
    So is the Vanilla coil over junk?
  • 11-02-2012
    cobba
  • 11-02-2012
    Radamus
    [QUOTE=cobba;9838196]http://www.bikepedia.com/quickbike/BikeSpecs.aspx?Year=2002&Brand=Jamis&Model=Dakar&T ype=bike#
    That's it! the 02' version. I see it was a $700 bike so on the cheaper side I would summize.
    Thanks cobba!!!
  • 11-02-2012
    cobba
    The same frame was on $2000, $1800, $1500 and $1000 bikes, the quality of the parts that is put on them relates to the different prices.
    How much do you want to spend on the build ?
    Do you want to buy new or second hand ?
  • 11-02-2012
    Radamus
    Yeah..that's the question :thumbsup: I checked out that site andrw posted on build kits. Been looking at those, and that looks like a good route to go. That $700 kit has my eye. There's a couple things I'd like to change but they are so low dollar it's irrelavent. That kit and a fork and I'm ridin. For me, it's not worth my time to spend days trying to save $50 when I'm looking at more than a g anyway. Looks like decent stuff on the main components. Grips, tires, seat not what I'd choose but that's little stuff.
    I've been watching the used postings on forks. There were a couple that looked like a good deal but I don't know enough yet about what does what to be buying anything.
    Andrw~ thanks for the pain article! good to know. Kind of the point of this bike, you have to go through some pain to get to the point where you don't hurt. I havn't played golf in 4 years because of the knee twisting. I was a poppin and a hoppin and occasionally droppin-LOL! I think I could do it now, but I want to bike first and use it to get me back out swinging again.
  • 11-02-2012
    FLMike
    Thanks cobba!!!
    and just confirming, that bike does have rear disc tabs on the frame?
  • 11-02-2012
    cobba
    What's in it, post a link.
  • 11-02-2012
    AndrwSwitch
    With rehab for overtraining injuries, the name of the game is "Pain is weakness entering the body." Be careful...
  • 11-02-2012
    Radamus
    Sram X.7 Disc Build Kit at Price Point
    Let me know what you think.
    Yes, has disc brake tabs, and cable holders. It had one on it, paint shows it had caliper bolted on it.
  • 11-02-2012
    shibiwan
    If it had discs at some point, the bike is likely a Dakar Comp or better....
    BikePedia - 2002 Jamis Dakar Comp Complete Bicycle
    SRAM/Avid brakes are pretty good, especially the X.7 and better, however I'd typically choose the brakeset to match the brand of the shifters if I can since some of them offer integrated brifter (brake+shifter) levers like the Shimano or like SRAM, a combo clamp to clamp both shifters and brakes together with one clamp.
    I'd recommend checking out the newer rear derailleurs with built-in damping clutches if you can afford them. These shift much better and eliminate chan slap if you ride on rough terrain a lot.
    You'll also probably need a headset for the frame/fork interface. You can look up the headset specs for your frame here:
    Headset Fit Finder
    There is a catch - the headset finder may be incorrect for some bikes like my Stumpjumper. Took me extensive checking to figure out the error.
  • 11-03-2012
    Dan Zulu
    You might want hydraulic brakes
    Since you said that you are an agressive rider I thought I'd mention the brakes in that build kit are cable actuated mechanical models. They are good, offer the mud resistant design advantage over rim brakes, have more stopping power than rim brakes, but won't give you the massive power that hydraulic brakes will. Right now I have cantilever brakes on my vintage bikes, and they're fine for my current trails, but if you are doing freeride/DH descents or riding in wet, muddy, or snowy terrain the hydraulic brakes would be worth the cost and maintenance quirks.
    Even though it would cost slightly more to buy the parts piecemail over eBay and the mtbr.com classifieds those are options. All in all I think that the best idea posted on this thread is to buy a second hand bike and cannabalize it for parts and sell whatever you don't use. There are often some crazy deals on Craigslist for good quality bikes.
  • 11-04-2012
    Radamus
    Thanks Dan for the reply. You are reading my mind really. So I've been looking at Ebay and CL and you are right. For example last night on ebay there was a Giant Trance X3, 2011 (in my size), shiny new. Guy was looking for $1450 or so - And it looks like that's where I'd be dollar wise fitting out my 10 year old Jamis - Kind of silly not to buy something like that. I would have snagged it up, but I'm still not to where I know enough to keep from getting screwed by ignorance.
  • 11-04-2012
    Dan Zulu
    You might want to sell the Jamis outright and put that towards a new or used bike. You are probably proficient at ebay and craigslist, but if you want some tactical ideas on either let me know.
  • 11-04-2012
    Radamus
    Giant Trance 1 Fox Float Shock Fox Fork RaceFace WTB Specialized Trek | eBay
    OK, Tell me if you think tis looks like a good value on a older bike built with good components? After looking at a ton of used bikes, I think this looks to be a decent deal for a guy who doesn't have to have the latest and the greatest.
    there is also a used, older, Rush 4 on ebay, It loos like a decent deal but he want's 165 for shipping, so makes it a $1400 bike.
    Cannondale Rush 4 New Price | eBay
    I will tell you something I never told anyone- there was a period of time I used to fall asleep with a Cannondale brochure and have dreams of blazing down a trail on a carbon Rush :D
  • 11-04-2012
    Dan Zulu
    Well the Cannondale is a size large and the Giant is a size small, so no matter how tall you are one of these bikes is not the correct size for you. The Giant listing says it is a size small and fits from 5'2" to 5'10" but I don't believe that broad of a range.
    I'm not really keen on the brand new market and cringe at the thought of spending more than 1000 on a bike no matter how awesome it is, but both look like reasonable values.
    Another approach to try is finding similar bikes that are plain auction format, ending in the middle of the night. You'll have no competition if you drop your bid in 15 seconds before it ends.
    Another approach is to check the buy it now listings, filtered by most recent posted, frequently, and eventually you'll be one of the first people to see a great deal posted. This way the listing is not posted long enough for the market forces of buyer competition to drive up the price. The tradeoff is that it requires patience and checking listings once or twice a day.
  • 11-04-2012
    AndrwSwitch
    In general, I think small bikes top out around a 5'8" rider. That's my height and I ride a medium with a stem size I like, but I'd only go up one or two stem sizes to ride a small, which I think would be okay-ish, and there's a lot of individual variation in how people like to set up their bikes.
    With a FS bike, I'd do some research into the record of the frame. Some FS linkages have problems with breaking. Others have proven to be pretty solid. If you're not the original purchaser, you don't get a warranty and this gets pretty relevant.
    Finally, don't send your money out of your community (and pay for shipping!) before you see if you can get something locally. Some bike shops will do consignment. You probably won't find outright used via a shop in that pricepoint, but certainly on Craig's List. And, don't discount 2012 bikes, which should be on clearance by now, and '11 bikes that may still be floating around in inventories.
  • 11-04-2012
    Radamus
    Thanks for the input!
    I am going to check a cpl local shops tomorrow.
    I questioned the sizing too. I think that Giant is too small for me anyway.
    I'll keep studying up!!
  • 11-05-2012
    shibiwan
    Can I interest you in a used Titus Carbon X ? lol.
    I picked up two of them today but turns out they are size L (closer to an XL - 21.25" seat tube length) and seems way too big for me (5' 5")....maybe I should just build them up anyways...
  • 11-05-2012
    Radamus
    Thanks Shibi- but carbon aint in this boys budget :D
    Great Deal Giant Trance x3 2011 Full Suspension Mountain Bike | eBay
    This is the one I thought I missed sat night but he re-posted.
  • 11-05-2012
    shibiwan
    Well, I PM'ed you. It'll fit your budget if you're looking at what the seller's asking for the Giant Trance. Perhaps we can work out something. ;)
    -S
  • 11-05-2012
    cobba
    Radamus the ebay bikes you're showing are all different frame sizes, it's no good getting a bike if it's the wrong size.
    Post some of your measurements and someone might be able to tell you roughly what what size frame you'll need.
    You could also try the following:
    http://www.competitivecyclist.com/za/CCY?PAGE=FIT_CALCULATOR_INTRO
  • 11-08-2012
    Radamus
    Thanks for that link Cobba! I'm zeroing in on size! Still studying and learning here.
  • 11-08-2012
    shibiwan
    Are you at least riding around on something right now?
    Overheard today at Sports Chalet: "You can adjust the fork (was a cheapie Suntour)... most important, do you like the bike color?"
    -S
  • 11-09-2012
    Radamus
    I have a cheapo road bike I ride around, but after riding my friends GT mountain bike I can't bring myself to take it off the rack anymore, imo it's a dumpster stuffer after riding something decent.
  • 11-09-2012
    AndrwSwitch
    Hang onto it.
    I don't know if you ever saw Breaking Away. There's a scene in which the protagonist race-preps a cheap Schwinn road bike. It takes an incredibly crappy road bike not to have some potential either with some TLC or as a singlespeed or fixie.
  • 11-09-2012
    Radamus
    Originally Posted by AndrwSwitch View Post
    Hang onto it.
    I do remember that movie! He was a "Cutter" poor kid who makes it big. I loved that movie! I was in HS when that came out and I think everybody bought a 10 speed if they didn't have one because of it.
  • 11-11-2012
    sauprankul
    Has the OP tried ebay build kits?
    Does anyone have experience with those?
    New Shimano Alivio M430 MTB Bike Group Groupset Hydraulic Brake Set M446 9 Speed | eBay
    Seems legit...
    Looks to be rebranded Deore or something. Comes w/ everything you need, including decent Hydro brakes.
    Bi King 2012 Shimano Dyna Sys Deore M596 MTB Group Set 3X10SP 8pcs | eBay
    Branded Deore.
    It's really risky, but if those guys come through, you'll have a full Deore drivetrain + brakes and a lot of money to spare. A LOT, and that money can go towards a way better fork.
  • 11-12-2012
    cobba
    Seems legit...
    Branded Deore.
    * I think that the OP has given up on the idea of building a bike and is going to get a complete bike that doesn't need work on it.
    * Plenty of people have bought those from ebay but they aren't always the bargain that they seem.
    Some bike shops such as bike-discount.de, bike24.com, bike-components.de, merlincycles.com, etc, etc, often sell groupsets cheaper then the ebay sellers.
    * Buying from these ebay sellers isn't as risky as you think, look at how many items the sellers have sold and look at the positive feedback from the buyers. There is some negative and neutral feedback but even online bike shops will get similar complaints from buyers. If you buy from ebay sellers make sure they have a good selling reputation, check out their feedback, ask plenty of questions, make sure you know exactly what you're buying before you bid or buy, don't expect next day delivery if it's coming from half way around the world, be aware of customs fees that you might have to pay on imported goods, etc, etc.
    What do you mean by 'rebranded Deore', it's either Deore or it isn't.
  • 11-12-2012
    sauprankul
    */very smart.*/
    */cool, you know any more websites?*/
    */ I'm not sure. I heard it somewhere. I think they mean it utilizes the same design + technology but with Alivio standards (quality/durability/materials)*/
  • 11-13-2012
    Radamus
    Right on Cobba~ I did buy a complete bike so my questions will continue shortly. So my plan now is~ I will see what I like and don't like, and as I upgrade it, those parts I'll put on my Jamis frame and off that at some time, or maybe I'll end up liking it? who knows..
    FWIW, Shibiwan has a BEAUTIFUL Titus carbon X, but try as I might, it's just too big...and believe me, I ground on the numbers a few sleepless nights but it just wasn't going to work. I tried some bikes the same size at LBS and no way..... stretch was too far---
    I picked up an older Titus Quasimoto. It has some top shelf stuff, some OK stuff on it and some junk I'm sure. At least I'll know how they go together, how they work and I'll ask some of the EASIEST questions you ever had!
    You guys have been great with all your help! Special thanks to Shibi~ been a lot of help.... man, why couldn't that carbon X have been a M?..... LOLOLO! I know, then you would keep it! she's a beauty!
    Cheers!
  • 11-13-2012
    shibiwan
    Cheers!
    PICS PICS PICS!! Post them asap! Was that the one you were showing me the other day?
    BTW, thanks for the plug. :)
    In case anyone's interested... (cheap!!)
    More pics here: https://picasaweb.google.com/1119949...sXCarbonFrame#
    Wife put her foot down and said I have "too much bike" in the house. So I'm trying to get all the small parts to complete the bikes (I got a black one too) and then hope to find good homes for them. Both are L frames. If one of them was at least an M, I'd have kept one.
    -S
  • 11-13-2012
    shibiwan
    Hang onto it.
    Prepping the Schwinn like this "racing" Trek on Craigslist?
    hehe
    -S
  • 11-13-2012
    AndrwSwitch
    LOL. That looks more like it got prepped in a scene in "Breaking Bad."
  • 11-14-2012
    Radamus
    That was the one- I asked some questions and made him an offer and he took it. I researched the reviews on MTBR on each component and I couldn't duplicate it in used parts for the price I offered.
    Question, wheels are a mix, it has Chris King headset/rear hub and Thompson stem/clamp stuff, DHX 5.0 shock and Marzocchi bomber fork. SRAM X9 gear with the twisty shifters and Magura hyd brakes and raceface crank. how does this arrangment sound?
    I'm really falling for the Cobalt Iodine wheels, thinking about Shimano shifters/derails and scouting hard for a Fox Talas fork. Anyone got a used set of Spank Spike pedals? :D
    Hey, I'm a noob- just hand my wallet back when your done :thumbsup:
  • 11-15-2012
    shibiwan
    Nice setup!
    I'd keep the SRAM X9 rear derailleur and stick to SRAM shifters. Having used both Shimano and SRAM derailleurs and trigger shifters, I find the SRAM design works a lot better, feels snappier, smoother, and give a very positive click when shifting between gears, probably due to the 1:1 pull ratio of the SRAM. To me, the Shimano shifters now feel very vague and require a little more force to shift, and being able to compare them side by side (both are relatively new) makes the difference even more noticeable.
    Race Face cranksets are great. Can't go wrong with them - have RF Evolve cranksets on both my bikes, and I've been considering moving up to the RF Turbine series crankset, but I can't justify the upgrade since what I have works nicely.
    You'll also enjoy the TALAS fork.... got one on my Stumpjumper and it feels great once I got everything dialed in. Make sure you're not getting one with so much travel that it'll affect the geometry of the bike significantly though.
    -S
