Results 1 to 8 of 8
    Reputation: Coach-Z's Avatar
    Jun 2014
    need new rear wheel suggestions
    I ride a 26" 2011 Marin Rift Zone XC8...
    I need a new complete rear wheel, thats cheap and will take my 9 speed cassette.
    I use 2.25 Nobby Nic tires from Schwalbe.
    Been looking at chainreactioncycles.com which is my favorite place to shop.
    Any ideas on what to look for?
    Fat-tired Roadie
    Nov 2007
    I like bicyclewheelwarehouse.com for wheels.
    Look for something (wherever you shop) that uses parts you can get easily as maintenance parts. I like a traditional 32-spoke construction using double-butted J-bend spokes. Hubs should be either sealed bearing or Shimano. Make sure you can get a replacement freehub. Make sure not to get the wrong kind of axle or brake mount. I'm betting you have quick releases on both wheels and disc brakes? So you'd want the same, preferably with the same attachment style for the rotors.
    Some people break a lot of Shimano freehubs, but they've always been pretty reliable for me.
    Jun 2014
    Sv: need new rear wheel suggestions
    Where does bicyclewheelwarehouse.com ship from?
    This is a picture of what I have right now
    Could you post a link for a suggestion of what you would get for 2-300$?? Just the rear wheel.
    Sendt fra min GT-N7100 med Tapatalk
    Fat-tired Roadie
    Nov 2007
    California. That's a traditional quick release and six-bolt rotor. I'd be on the fence about a complete wheel - what's wrong with what you've got? When it came up for me, I got a set, Sun DS1-XC rims on DT 360 hubs, for $200. They were an order cancelation, I think, but you could definitely get a set along those lines - I didn't save that much against list.
    Jun 2014
    The one I've got is all wobbly.. It might just need to be realligned, but I think it's been bent..
    Fat-tired Roadie
    Nov 2007
    First line of defense is to try to true the wheel. Next would be a 1:1 rim swap, but since that's getting into more expense and trouble, if you want a new wheel anyway, it's a good excuse. Just know that you don't have to. It's actually a pretty easy task.
    If you have to replace the spokes too, it's hard to keep the project under $100. You can buy a disposable wheel for that.
    I built a wheel around an M-475 hub a while ago, because I needed a disc wheel for a road bike. Most people wouldn't save this hub, me included if the project had been about having a nice wheel. But it's been doing fine since then.
    Jan 2005
    Do you want to run tubeless? If yes, you might have a look at Shimano MT66 wheels, they are SLX grade, rims have UST profile and can be made airtight with some tape. As I was told by someone here, the SLX freehub body is more reliable than Deore or XT.
    CRC has these wheels as wheelsets or separately.
    May 2014
    I bought a Fulcrum Red Power XL for $130 brand new on Ebay. I have been very happy with the wheel and it helped me shave some weight as well.
  1. any suggestions for rear wheel upgrade?
    By weekendthrasher in forum General Discussion
    Last Post: 08-27-2013, 01:08 PM
  2. any suggestions for rear wheel upgrade?
    By weekendthrasher in forum Specialized
    Last Post: 08-27-2013, 08:49 AM
  3. Replies: 3
    Last Post: 07-20-2013, 10:34 AM
  4. Help!! Need suggestions for a cheap rear wheel.
    By knobby1 in forum Wheels and Tires
    Last Post: 08-05-2012, 10:53 AM
  5. Tire Suggestions please for rear wheel.
    By Okie Dokie in forum 29er Bikes
    Last Post: 05-01-2011, 10:29 AM
