Results 1 to 3 of 3
    Feb 2013
    Need help with new bike assembly (thru axle)!
    So I just received delivery of my gently used custom build Cannondale RZ 120. Assembly was a breeze until I tried securing the front wheel with a thru axle (maxle). I'm used to a quick release with the spring-loaded twisty cap on the other end. But this thru axle has no such thing and the wheel is very loose not having anything for the axle to screw into.
    I thought for sure I was missing some sort of cap to secure the wheel. But I looked through the eBay photos and there didn't seem to be a cap there either. What am I missing?
    Link to more photos and specs on ebay: Cannondale Rize 120 Large | eBay
    Reputation: Snfoilhat's Avatar
    May 2010
    Maxle installation
    0. Pull the maxle lever to the 'open' position
    1. Push maxle through fork dropout, hub, and into the opposite threaded dropout.
    2. Screw the maxle in hand-tight
    3. Flip the lever to the closed position
    If your "loose" is happening at step #2, you may have some issue.
    If your "loose" is happening at step #3, all you have to do is use a small allen wrench (3mm? it's the same as the built-in allen of a Rockshock rebound knob--you can pull it right out) to tighten the hex hidden inside the lever end of the maxle. This adjusts the wedge that expands when you flip the lever. The little adjuster may be backed so far out that even w/ the lever flipped closed, it does not tighten up.
    Does that help?
    Feb 2013
    Thanks that did it!
  1. Replies: 30
    Last Post: 04-21-2017, 06:00 PM
  2. Replies: 2
    Last Post: 01-23-2013, 10:20 AM
  3. XPOST XTR pedal M980 axle snapped - axle assembly availability?
    By aussie_yeti in forum XC Racing and Training
    Last Post: 01-22-2013, 10:04 PM
  4. Tips For Shimano B-Axle Assembly Replacement
    By ryanstrive in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-16-2012, 08:43 AM
  5. XPOST XTR pedal M980 axle snapped - axle assembly availability?
    By aussie_yeti in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-12-2011, 09:09 AM
