Results 1 to 6 of 6
    Sep 2014
    need a bit of jump help
    Ok recently joined cuz I have trouble with one thing since I have started biking last summer. I still can't do jumps. I don't know if it's just me getting intimidated or I'm doing something wrong. I get into attack position before the jump and all that jazz then I loosen up and I'm in the air well about an inch off the ground. AND I GO ON BIG JUMPS! I don't get it but I practice whenever I can with school back and I have to practice the sax and homework but I can luckily get to the jumps for about a half hour but help would be appreciated
    You need to go faster... And let the bike do some of the work. There's a ton of instructional videos on YouTube that will help you get the idea but it's really just practice.. Can you wheelie and bunny hop? That's really the beginning stages.. Having full control over the bike. After that you should feel more confident to try hitting jumps looser at faster speeds.
    Sent from my 831C using Tapatalk
    Reputation: dirtyBob's Avatar
    Jun 2005
    ditto to that. gotta put in time. time learning to pull up the front as high as you can while just toodling around town. lift it over a hose, then a 2x4, then up curbs, and when you can get it really high- like flipping it over or at least getting it close to your chest- learn to bunnyhop. it's not that you have to bunnyhop off every jump- speed and a ramp can certainly put you in the air- but knowing how to control your bike in the air in what would otherwise feel like awkward positions- is what's going to help you with jumping. Then... you gotta put in the time jumping. if you do a little practice at all these things every time you ride, you'll be much better next year same time.
    Over the Bars - the mtn biking comic
    Find a place to practice drops too.. Try to get the landing part down as well. There's a lot that goes into jumping but all of it involves control of the bike. You're getting scared right before take off because you don't have the confidence.. And adding all these skills will help with that.
    Reputation: Trail_Blazer's Avatar
    May 2012
    Learn to bunny hop 12 inces off the ground and then do it at the crest of hills.
    Fat-tired Roadie
    Nov 2007
    Don't be too loose going over jumps. You don't want to be so stiff you lose control, but your arms and legs are your main suspension. Riding over jumps loose lets you absorb them. Which is the opposite of what you're trying to do.
    Practicing bunny hops is good advice.
    I'm the first to admit I'm not particularly good in the air. But for me, the initiation feels most like a manual.
  1. Man I can't jump!!!
    By Tom-Cat in forum General Discussion
    Last Post: 08-07-2014, 02:33 PM
  2. How to hit that jump you ask?
    By PSLICE in forum Colorado - Front Range
    Last Post: 07-14-2011, 11:34 PM
  3. Should I jump on this?
    By mvallejo in forum Trek
    Last Post: 06-15-2011, 06:32 PM
  4. Did I jump the gun?
    By fruitbooter in forum General Discussion
    Last Post: 04-11-2011, 06:02 AM
  5. Should I jump on these?
    By ziglaf in forum General Discussion
    Last Post: 02-23-2011, 05:35 PM
