1. The most important thing about buying a new bike is to make sure it fits. The only way you'll know if the bike is right for you is to size up the bike and make sure that the bike's geometry matches your body's geometry. Ask questions and do some research.
mtn. biking 101
2. If possible, try to find a shop that will let you demo the bike on real dirt. Five minutes in a parking lot won't cut it. You wouldn't buy a car without a real world test drive, and a bike should be no different.
3. Don't belive the hype. Just because your favorite rider or best friend rides a certain bike, that doesn't mean that's the best one for you. Have an open mind and be realistic about your needs and ability.
Results 1 to 5 of 5
    Reputation: Iksobarg's Avatar
    Mar 2012
    My Ooold 2002 Specialized FSR Stumpjumper needs which bottom bracket?
    Hello MTBR Friends,
    I got an easy one for you today. (Sorry!, Ok?!)
    Have bottom brackets for Mt Bikes changed any since 2002?
    I don't know so via weblink or precise description/part number, could someone please tell me which bottom bracket I need to order?
    It's an old 2002 Specialized M4 Stumpjumper
    I give you my baby (go ahead and laugh) but do throw me a bone while you are at it.
    Many thanks in advance!
    John
    I often start riding and cannot stop.
    since 3/10/2009
    Reputation: Harold's Avatar
    there are new BB standards (mostly surrounding press-fit bb shells), but the old ones are still around.
    You just have to choose the right one for your bb shell and the crankset you wish to use.
    Mar 2012
    I must be slipping...
    Why didn't I just look up the specs?
    I did and found it:
    Shimano BB-ES50, 113mm spindle
    I was pretty busy today and just didn't foresee this...
    Thanks for your time!
    John
    Bottom brackets have changed a lot since 2002, but luckily companies still offer replacements that will fit older bikes.
    2002 Specialized Stumpjumper FSR XC Disc - BikePedia
    The stock BB should have an octalink spindle. If so, you could just order a Shimano ES25 or ES51 in 113mm spindle and 68mm BB shell and it should work. If you're doing the work yourself, you'll also need to make sure you have the correct crank arm puller and BB tool.
    If your rings have enough wear to warrant changing and you want to step into the next decade, something like a shimano m590 costs less than a big bill with a bb. External bearings vs your cartridge bb.
  1. Fox Float R on a 2002 Specialized Stumpjumper FSR
    By mastee in forum Shocks and Suspension
    Last Post: 06-08-2014, 10:51 AM
  2. Specialized stumpjumper fsr xc SHOCK LINK Yr 2002
    By shinyballs in forum Shocks and Suspension
    Last Post: 04-21-2014, 10:14 PM
  3. Bottom bracket for 2002 giant team dh
    By Gnome_1080 in forum General Discussion
    Last Post: 05-22-2013, 05:30 PM
  4. stumpjumper bottom bracket
    By chrishei1 in forum Specialized
    Last Post: 10-04-2012, 12:31 PM
  5. Replies: 1
    Last Post: 03-24-2011, 07:18 AM
