Results 1 to 14 of 14
    Cool-blue Rhythm My front end comes up during climb
    There's quite a few hills on my local trail that at the top or the middle of a climb. My front wheel leaves the ground. Sometimes this results in me falling off and rolling down the hill lol.
    If I lean too forward my rear wheel loses traction. While my skills and balance is improving, is there anything to help mechanically? Someone suggested changing my stem to a 6 degree 100mm? My stocker on my '11 Giant Revel 0 is a 15 degree stem and it is short. I guessimate about 65mm.
    Thoughts? Suggestions?
    Reputation: fireball_jones's Avatar
    If you feel cramped, then a longer stem might help, however if you're stretched correctly at that stem length, a long one will only make riding the bike worse.
    While a lot of getting a hardtail up steep inclines is being in the right gear and being able to balance, if your rear tire is too eager to spin, you might want to look for one that digs in more, or is better suited to the conditions you ride in. Rarely are stock tires perfect for where you ride.
    Reputation: Gasp4Air's Avatar
    It sounds like when you keep enough weight forward to maintain control of the front, you spin out in back, and if you keep enough weight on the rear wheel, the front goes floppy on you. The way to keep weight forward and back at the same time is this: slide your butt to the nose of the saddle so it is planted firmly in your taint (taint what's in front, taint what's in back, it just taint!). At the same time, pull your upper body down to the bars. Then just spin. How far onto the nose and how far down to the bars is determined by the steepness of the climb - you have to experiment. If this works for you, you may want to find a taint friendly saddle - some are much better than others. Droopy and/or wide nose is the thing to look for.
    Use it, use it, use it while you still have it.
    Reputation: el_burras's Avatar
    Mar 2011
    The first thing to do is RELAX, if you have your arms and hands choking your handlebar and grips is more likely your going to loose control over your bike, let it breathe and she will take care of you.
    Second, whenever you start climbing set your right gear, DO NOT SHIFT in the middle of the hill, this will put a lot of stress on your drive train and you may damage it AND MOST LIKELY YOU WILL LOOSE MOMENTUM.Start climbing on a conformable gear.
    Third, choose the line your going to take uphill, once you do don't change it, follow that line, remember YOUR BIKE WILL FOLLOW YOUR EYES.
    Fourth, move forward on your seat, this will balance the weight between front and back tires, one thing to remember RELAX, DON'T CHOKE YOUR HANDLEBAR.
    RELAX AND ENJOY, YOUR BIKE WILL TAKE CARE OF IT, ALSO ALWAYS PEDAL SITTING DOWN, DO NOT STAND UP, YOU'LL GAIN MORE STRENGTH ON YOUR LEGS IF YOU PEDAL SITTING DOWN
    Reputation: Nick_Good's Avatar
    Jan 2011
    What works for me when it gets real steep is getting in an easy gear, sliding forward to the nose of the seat, keeping my elbows in and pulling back on the bars a bit. So far this has worked for me; especially when it is a steep, loose, rocky uphill grind. BTW i also have a Revel 0. It's a good bike for the price. Getting ready to ditch the BB5's for BB7's and eventually swap the Dart 2 for a Tora. Those are the only upgrades I see for it.
    -Nick
    Best Balance point:
    The tip of the saddle is pointed up where the sum don't shine
    Reputation: marpilli's Avatar
    Successfully riding up an incline like that is akin to a golf swing. There are a ton of factors and you have to get them right (and understand them) in order to make it a repeatable process.
    I'm getting better at the steep, short inclines. I still stall out on a few of them.
    The things I'm doing that seem to help (some previously mentioned by others):
    1) Get in a low gear and stay there
    2) Lean forward to help keep that front wheel down
    3) Scoot forward on the seat so I'm sitting on the "nose"
    4) Gently "pull back" on the handlebars about half way up the climb to dig in the rear tire so I don't loose traction
    5) Keep my eyes on the line I'm attempting to take, not looking down at the tire
    6) If I can, gather some speed right before the incline so the momentum will help carry me up as far as I can get.
    7) Run lower pressure in my rear tire to increase traction
    I'm sure there are other things. This is all I could think of for now. Oh, and practice, practice, practice.
    Finding a line on some of my climbs still seems impossible. But, a few I previously thought were impossible I can now accomplish. Same will happen with you.
    I had the same problem, sans the rolling down the hill. If you have any spacers below your stem move one or two of them above your stem.
    Quote Originally Posted by CoffeeRoaster View Post
    Very good idea. No cost, easy way to lower your handlebar and help keep the front end down.
    I had the same issue. I figured out that I was pedaling to hard. Once I smoothed out my pedaling I have no more problems.
    Reputation: tshulthise's Avatar
    Quote Originally Posted by pawa_k2001 View Post
    +1
    If you are balanced so that your front end is just under control then you can't do anything more to improve balance other than keeping your weight distributed there the whole climb and not being jerky. That leaves you with pedaling very smoothly so you don't pulse the rear wheel and having the right tire and tire pressure for the terrain you are riding.
    Reputation: Andy Pancroft's Avatar
    I'm kind of a - don't buy into all this overthinking stuff - guy. Your prob is simply too much torque - your pedaling hard enough do pull a wheelie; smaller gear and easy/smooth pedaling. Back in the day before stems - when they were known as goosenecks - we were able to get our bikes successfully up hills.
    Try this and add a couple Dale's Pale Ales to your bottle cages and you'll be fine!!
    Quote Originally Posted by Andy Pancroft View Post
    This advice won't get you very far. Technical climbs aren't the same as riding up a steep driveway when we were kids. A steep technical climb requires technique and skill to pull off... smooth pedaling is just one component of many needed.
    I agree that this helps. I break my rear tire loose if I'm stomping on the pedals during a climb.
    I'm willing to bet you're doing some of the other stuff (maybe subconsciously) like leaning forward, also...
  1. Which Front Range Trail do you think is the toughest climb?
    By Thrasher in forum Colorado - Front Range
    Last Post: 06-04-2012, 01:16 PM
  2. Best Front Range Climb
    By drmaino in forum Colorado - Front Range
    Last Post: 01-19-2011, 11:09 AM
  3. Biggest climb on the Front Range?
    By titusguy in forum Colorado - Front Range
    Last Post: 05-07-2010, 12:46 AM
  4. Front wheel lifting during a climb
    By elistan in forum XC Racing and Training
    Last Post: 08-30-2004, 01:02 PM
  5. Light front wheel during steep climb
    By JerryBoneJr in forum XC Racing and Training
    Last Post: 05-11-2004, 12:58 PM
