Results 1 to 35 of 35
Thread: my butt hurts
    Reputation: Waltah's Avatar
    my butt hurts
    yea, only been on the bike 15 miles and boy, the stock seat is not so forgiving. do i need to invest in cycling pants or a better seator am i just a wimp?
    thanks folks.
    Gary Fisher HiFi Deluxe 29er
    Reputation: Nick_Good's Avatar
    Jan 2011
    Give it time and it will get better.
    Reputation: pattongb's Avatar
    Listen to Nick.
    My as# hurt like hell the first 2 weeks, but it really does 'adapt' and gets much better. I did find a nice pair of racing shorts that look like real shorts (read baggy) but have the pads on the hind end. These make a world of difference and I got them at the local sports store for $20.
    yea, did some searching on here. didnt realize it was something that i would get used to.
    i think my LBS tech was explaining to me that i would have sore muscles after my first few rides, maybe he was trying to tell me my ass would hurt in a polite manner. i run and play hockey so i know my core is fairly strong. makes sense that the only thing that is sore is my bum.
    Reputation: nikojan's Avatar
    Quote Originally Posted by Nick_Good View Post
    Until you sit on an old shitty walmart bike with a fat saddle that makes you question every bike related dicision you've ever made
    Honestly though, it does get better but only because you don't notice the pain after awhile. I'm planning on dishing out a bit on a really great saddle really soon.
    "Nothing compares to the simple pleasure of a bike ride." - John F. Kennedy
    Setup:
    11' Giant XTC 2 29er
    What does a bean mean?!
    Reputation: COTarHeel's Avatar
    It really is true, the more you ride the less your butt will hurt.
    I'd still recommend getting some bike shorts though. Not only will they give you a little cushion, but they can help prevent chafing too. And don't fall for buying a super-soft saddle. Excessive padding can increase the pressure between your load-bearing butt bones, which isn't good and can lead to problems worse than sore cheeks.
    DONT go for the "fat boy" seat! not even a seat cover. im guessing you have two distinct sore spots, one on each butt cheek. its where you ass bone hs been smashing your tissue. it will go away, much like soreness after your first workout
    Reputation: ghettocop's Avatar
    I would suggest if you are going to do any kind of regular riding, cycling shorts are a must. You can get the mtb variety where the roadie short is sewn into a pair of loose more fashionable cool guy shorts if you want.
    Quote Originally Posted by ghettocop View Post
    ^^ Thats what I got! They are great!
    Quote Originally Posted by SantaCruzGoblin View Post
    correct, thats exactly where i am sore
    thanks, going to the sports store tomorrow
    Nickel Havr
    Reputation: Eckstream1's Avatar
    Check that your seat is in the right position... I always run the nose of the seat down just a little bit.
    Quote Originally Posted by William Blake
    Great things are done when men and mountains meet. This is not done by jostling in the street .
    ummmm.. what!?
    Jan 2011
    Since I've gotten back into mountain biking... my ass still hurts after a days ride. Found out it mostly just my saddle. Bought a bike sporting a selle italia saddle and thought ooooo pricey must be nice. Its not. Sat on my brothers speed v today.. man what a difference. Probably why he's so slow.. too much time spent sitting in the saddle..
    Its a JEEP thing. I have 4 and still don't understand..
    Just Ride
    Reputation: Cormac's Avatar
    My ass killed me first few days too. Now I don't even notice the seat really.
    thanks for the tips folks. if im still sore after a couple weeks ill tweak or invest accordingly.
    your ass will definitely build up a resistance the more you ride. Another tip I was given when I first started to ride was to lift up off the saddle a bit when you ride over roots or anything bumpy or rocky, that way your ass won't take so much of it
    Ride,Smile, Pedal Damn it
    Reputation: henrymiller1's Avatar
    Loose the gears, stand up, and "pedal Damn it"
    Reputation: cerebroside's Avatar
    I've been riding on rock hard seats since I was a kid (my dad is a die-hard road biker). I was always told that a soft seat is worse on long rides. Any truth to that?
    Reputation: Markus_037's Avatar
    i got fed up with my stock one and got a nice foam one for $30. i forget the name but theres a lot more padding and its more forgiving. u dont want one thats super soft either because it will bottom out and ur ass will be on the base of the saddle.
    Reputation: madaxc's Avatar
    Fantastic thread title!
    Quote Originally Posted by cerebroside View Post
    Yes! The saddle doesn't have to be rock hard though, there is a middle ground.
    From ye olde Sheldon Brown:
    When a cyclist finds a saddle uncomfortable, the first impulse is often to look for a soft one. This is often a mistake. Just as the softest mattress is not necessarily the most comfortable to sleep on, the softest saddle is not the most comfortable to cycle on.
    Imagine sitting down on a coffee table. Your weight is concentrated on the two bumps of your "sit bones", also known as the "ischial tuberosities." These are the parts of your body designed to bear your seated weight. Most cases of saddle-related discomfort arise because the load is carried on the soft tissues between the sit bones.
    Imagine placing a soft pillow on top of the coffee table. Now, as you sit down on it, the sit bones compress the pillow, which yields until the sit bones are almost on the table surface again. The difference is that now, you have pressure in between your sit bones from the middle part of the pillow.
    In the same way, a saddle with excessively soft, thick padding can make you less comfortable by increasing the pressure between your sit bones.
    Many cyclists are unaware of this, and many saddles are made to appeal to the purchaser who chooses a saddle on the basis of how easily the thumb can sink into the squishy top. This type of saddle is only comfortable for very short rides, (though an inexperienced cyclist will often find it more comfortable than a better saddle, as long as rides don't exceed a mile or two.)
    Saddles with excessive padding are also a common cause of painful chafing of the inner thigh, as rides become longer.
    Also keep in mind that a saddle isn't supposed to support all your weight. Your legs and arms should be carrying some of the load too.
    My comfiest saddle is my smallest and least cushioned one.
    local jackass
    Reputation: biggoofy1's Avatar
    My roadie seat has very little padding and I love it. My Mtb is a wtb vigo very comfy but not to much padding.
    His
    2010 FSR XC
    2010 ALLEZ
    Hers
    2012 Myka 29'r
    2009 Cannondale Synapse 5
    Down East Cyclists
    Try a couple of things
    Quote Originally Posted by Waltah View Post
    thanks folks.
    First, it's all true you will develop less pain as you ride. A good pair of shorts with a chamois (either sewn in, or removeable) is a great investment.
    ALSO, don't pass up on using a chamois cream ( ASSOS or Chamois Butt'r ) on the pad and also wherever you might chafe (inside thighs, depends on your body shape).
    I have been wearing the baggy style shorts with sewn in pads for years ( my favorites are the NEMA Crown Jewel, but they fit tight when I gain too much waist (weight)) but I always use the chamois cream. Prevents thigh chafing and ass rub.
    Good luck.
    local trails rider
    Reputation: perttime's Avatar
    Aug 2005
    Better keep your rides on the short side until you get used to saddle time. Pain is not fun.
    I do OK with non-padded shorts/pants but I am probably in a minority. On trails I'm out of the saddle a lot, riding singlespeed, but a couple of hours of seated riding on roads and streets goes without pains too. I've been doing it for a while and have seats that suit me....
    "it IS possible that you are faster or slower than anybody else who is having at least as much if not more or less fun"
    I went out and got the fox launch shorts after my first day of riding left my rear end completely sore and after that day never had an issue once I got the shorts. The thin layer of padding makes a hugeeee difference !
    felt a bit better today but 9.5 miles of trail riding certainly didnt help.
    So, am I defeating the purpose of my really nice Selle Italia saddle by putting a Sorbothane cover pad on it?
    Hi Waltah,
    Seems like you have ride 15 miles for the first time.
    It will take some time, better to be more consistent to get rid of pain.
    One olther suggestion: Do not wear underwear under neath the bike shorts. Wear the bikes shorts as your underwear. the seams in regular undewear chafe your butt.
    I ride roadies and MTB and I just switched from Pearl Izumi Attack shorts to Pearl Izumi Pro In-
    R-Cool shorts and/or Assos shorts and there is a huge difference in comfort level on long rides.
    Wayne
    you get used to it
    Reputation: Gasp4Air's Avatar
    As others above have said, your butt has a break-in period. But having a saddle that plays nicely with the shape of your own personal tush matters too. So get some padded shorts and continue with your current saddle . If you're still having problems after 10 more rides, you may want to try a different saddle. Remember, moderate padding is ok, but don't overdo it.
    Use it, use it, use it while you still have it.
    I never wear true bike shorts, but the only time I've ever had my ass hurt is when I go riding the canal or rail trails, but that's because I usually do 50+ miles at a time on those trails and am riding the entire day.
    Riding 15-20 miles or so I usually do on the trails, don't normally have any problem but then for a good bit I'm not sitting at all.
    Now that winters coming up I need to get some good bike pants though because I want to do winter riding. Can anyone suggest some?
    50miles on an offroad trail? i would be dead.
    literally
    No, the canal and rail trails around here are gravel trails. Not technically "road" but not off road really. 50 Miles isn't that big a deal because you're usually in your fastest gears and hauling along.
    Offroad trails I usually try to do ~15 miles, all depends on the mood I'm in and where I'm riding.
    Walthal - I am a noob - been riding 3 months and ride almost every day. I literally feel your pain. I had the same issue. It did get better after about two weeks but still not great. I changed seats and instant relief. I have an entry level Scott 29'er and the stock seat looked cool and probably fit somebody but not me... My limited experience would say ride a couple of weeks to toughen your butt and if you are not totally comfortable get another seat... I would add also make sure you are fixing the right thing - chaffing is different than pain where you sit....
  1. My butt hurts
    By tonkota in forum Beginner's Corner
    Last Post: 06-19-2008, 12:50 PM
  2. My butt hurts.....
    By canyon_fishy in forum Beginner's Corner
    Last Post: 01-23-2008, 01:49 PM
  3. My butt hurts, butt off seat more?
    By bandit390 in forum Beginner's Corner
    Last Post: 11-06-2006, 07:03 PM
  4. Butt hurts
    By jbswads in forum Beginner's Corner
    Last Post: 06-18-2006, 09:33 PM
  5. My butt hurts
    By dvspd in forum New York - New Jersey
    Last Post: 04-10-2006, 04:09 PM
