Page 7 of 7 FirstFirst ... 34567
Results 301 to 347 of 347
Thread: MTBR Glossary
  1. #301
    Jan 2013
    5 minute on this post, worth it!! thx mate!
  2. #302
    OEM
    In the car world it means original equipment manufacturer. Same thing here? I keep seeing people refer to components from certain online retailers as OEM.
  3. #303
    Huckin' trails
    Reputation: David C's Avatar
    MTBR Glossary
    Quote Originally Posted by Zachua View Post
    OEM
    Yup, and mostly just OE (original equipment). Also sometimes you'll see Take-Off, which is a part that has been taken off a bike and put for sale, often new or in very good condition, but not necessarily an OE part, since many particular seller will do this as well as retailers. Even more, both OE and Take-Off parts will not come with any retail packaging or user manual/documentation, as well as extras or supplied parts (like an allen/torx wrench for disc brake kit). However, OE and new Take-Off should always be brand new never used and come with the same warranty (if sold ** a retailer) as normal, unless specified.
    Quote Originally Posted by NicoleB28 View Post
    topless. that's what all mtb girls do. we go ride, get topless, have pillow fights in the woods, scissor, then ride home!
  4. #304
    Jan 2013
    Thanks very much. I'm sure I'll be referring back to this quite often for awhile.
  5. #305
    Feb 2013
    This is great info. Thanks all!
  6. #306
    Feb 2013
    This helps quite a bit...
  7. #307
    Feb 2013
    Ah there were a few I was wondering about. Cheers
  8. #308
    Mar 2012
    Good Stuff
  9. #309
    Feb 2013
    Thanks for the info.
  10. #310
    Feb 2013
    glad I saw this thread
  11. #311
    local trails rider
    Reputation: perttime's Avatar
    Aug 2005
    OEM
    Quote Originally Posted by David C View Post
    Yup, and mostly just OE (original equipment). Also sometimes you'll see Take-Off, ...
    ... both OE and Take-Off parts will not come with any retail packaging or user manual/documentation, as well as extras or supplied parts...
    Another thing is: OEM tends to refer to the BIKE manufacturer, not the component manufacturer.
    Component manufacturers sometimes supply large bike companies with parts that are made to the bike company's specs, and are not available elsewhere. For example, an OEM fork might have a different set of features, compared with forks that are otherwise available. Or an OEM shock might have some special tuning tailored for a particular bike design (and less suited for some other design).
    "it IS possible that you are faster or slower than anybody else who is having at least as much if not more or less fun"
  12. #312
    Feb 2013
    Very Helpful
  13. #313
    Mar 2013
    Very Informational!
  14. #314
    reading comprehension wat
    Reputation: dv8xin's Avatar
    Mar 2013
    PITA to have to learn all these acronyms, IMO.
    THX OP.
    I got hung up on stupid things like the difference between rigid and HT and also getting to know if there was any difference between 15QR and 15mm TA.
    Wait until you get to all the #s like 31.6, 31.8, 30.9, 27.2, 34.9, 68/73mm, 156Q, 56ZS, 49EC, 44IS, 57-599, 1/2" x 3/32", 180/185mm, 120/80 BCD, DOT 4, DOT 4.1, DOT 5, 1.2mm x 2000, etc. Watch out for mixed metric/imperial measurements and conversions... 5" of travel is how much in mm, 120, 125, or 127mm?
    Watch out for all the brand specific acronyms too, like RLC, RC2, RC3, RCT3, TST, BB30, PF30, PF92, BB95, etc.
    Then there's always the frame fit jargon, like SO, ST, HT, ETT, etc.
    Deciding to buy a frame, after buying and riding an used high performance bike and getting spoiled by nice parts, and comparing to other frames and then deciding to spec it nicely, has been fairly complex learning experience. I could probably spend another week surfing this board, but in the end, I bet I will still find myself to be stupid and uninformed, unable to find answers to any of my questions really, and with an emptying bank account. I don't think others with 1000s of posts and years of surfing this forum are really any better off than me, except maybe they learned to close their minds after allowing all this questionable knowledge swell their heads.
  15. #315
    Mar 2013
    MAMIL - middle-aged men in lycra.
    Found it in a bike review quote, "balanced and comfortable enough to get the most hamfisted MAMIL to the end of a sportive feeling like a pro."
  16. #316
    Quote Originally Posted by dv8xin View Post
    ...And lookin' like a dummy.
    roccowt.
    rocnbikemeld
  17. #317
    Nice work!
    Here's my take on a few that I disagree about.
    Quick facts :
    • Do not remove factory lube from a new chain, just wipe off excess with a rag when getting dirty.
      factory chain lube is good for keeping a chain new on the shelf. it prevents corrosion. It is also good for ensuring that any dirt that gets near your chain clings to it and works its way inside the chain. Leave it on at your own risk
    • 1/2" pedals threads are mainly for BMX use. 9/16" threads are more common for MTB and road use.
      1/2" pedal threads are for 1 piece cranks (only on the cheapest modern bikes) typically and 9/16" threads go with essentially all nicer cranks; there is not a distinction between bmx and mtb.
    • Seat post should be inserted at least to the minimum insertion length and better if long enough to go past the seat tube - top tube junction of the frame to ensure maximum strength and prevent frame fatigue.
      minimum insertion marks on the post are for the integrity of the post. For conventional frames, ensure that your post is inserted to go at least a half inch beyond the bottom wall of the top tube, where it meets the seattube; ultimately the frame mfg may have a different recommendation than the seatpost mfg. make sure both are met.
    • Put a protector on the chainstay of your bike to prevent the chain from damaging it. A simple inner tube can be wrapped around with zip ties.
      this is only necessary for bikes that use springs to tension the chain. for many single speeds, this doesn't matter.
  18. #318
    local trails rider
    Aug 2005
    Quote Originally Posted by PretendGentleman View Post
    Nice work!
    Here's my take on one thing that I disagree about.
    All major chain manufacturers state that their Factory Lubes are probably the best thing for the internals of the chain.... as long as it lasts.
    The thing about exterior gunk is a very much separate thing. Wipe off the stuff from the exterior of the chain, maybe even with a rag that is wet with WD-40, or something. Add a thin layer of dry or waxy lube (maybe). But don't go soaking off the greasy stuff from the interior of the chain, until you have a good reason to.
  19. #319
    Mar 2013
    DINK - dual income, no kids
    "the stereotypical, middle-aged DINK who always has the latest gear despite carrying five extra kilos of body mass and displaying the handling prowess of a giraffe on a skating rink."
    I like to jump to conclusions, oversimplify, gossip, and participate in popularity polls.
  20. #320
    Jun 2013
    Forgive me if these questions have been answered on pages 2-11 but I didn't want to spend all day reading them. I was heavily into the MTB scene from 1990-1994 but sort of fell out out of it, then recently I've been getting back into it. As most FS bikes look the same to me (there's the ones that just look like bikes with a rear shock, then the bikes that look like motorcycles with no motors), I'm finding the miriad of MTB classifications confusing.
    1) Can a FS (full suspension) bike be considered XC?
    2) Can a hardtail be considered All Mountain?
    3) What are the differences between All Mountain, Over Mountain, Trail and Enduro?
  21. #321
    Huckin' trails
    MTBR Glossary
    Quote Originally Posted by Racnad View Post
    1 and 2, yes.
    3, they are pretty much all about riding bikes over chunky stuff and having a blast. Others will chime in on this. Endure is pretty much a competition though.
  22. #322
    Jun 2013
    THX OP.
    When most all bikes had a horizontal top tube, frame size was the distance between the center of the bottom bracket and the top of the top top. These days with sloping top tube and other exotic designs there's no standard for bike frame sizes. Add to that the fact that different people have different inseam, body and arm reach porportions, and these affect bike fit. Two people of the same height may not fit optimumly on the same bike. The only thing bike size labels are good for is a rough guide of which bikes in a shop you should try out.
  23. #323
    Jun 2013
    1 and 2, yes.
    By today's definitions, would my 2002 Cannondale Jekyll be considered XC or AM?
  24. #324
    Huckin' trails
    MTBR Glossary
    By today's definition, your bike is still for the same usage as when it was designed 12 years ago.
    My 2000 dual suspension XC bike is still for XC.
  25. #325
    Jun 2013
    Silly me! I thought these words all came into use during the past few years. I was looking though old files and found the 2002 Cannondale catalog from when I was last seriously shopping for a new bike. The Gemini was called "Freeride" and the Jekyll & Super-V were under "All Mountian." Way to pay attention!
  26. #326
    Glad to Be Alive
    Quote Originally Posted by highdelll View Post
    CHUM = Cycling Has an Ugly Moderator
    (just kiddin' Nick - you are pretty)
    SMT = Shiver me Timbers
  27. #327
    Jul 2013
    Re: MTBR Glossary
    What is EBB?
    What works for me may not work for you. What's best for you depends on many factors. We are different from each other.
  28. #328
    squish, squish in da fish
    Reputation: fishwrinkle's Avatar
    Eccentric Bottom Bracket - offset BB that can be used to tension a chain, is the most common use. think of a cam
  29. #329
    Self Appointed Judge&Jury
    Oct 2000
    Get connected, to a similar link.
    Bikes,parts & gear "Slang Terms"
    Dude, I'm in Illinois. The only place anyone would come from that would say this area is hilly is Kansas.
  30. #330
    Reputation: AK_Killem's Avatar
    Sep 2014
    Helpful thread for noobs like me.
  31. #331
    Dec 2014
    cool ... appreciated a lot....
  32. #332
    Cheesy Folk
    Reputation: Gorn1120's Avatar
    Jul 2015
    Perhaps a mod could edit the thread to update as necessary / new thread managed by an active member.
    My team is running/biking 185 miles each for wounded veterans!
    185forheroes.org
    Pledge $2 to my cause!
    (until July 2016)
  33. #333
    May 2016
    great info!
  34. #334
    May 2016
    Good to Know
  35. #335
    Jul 2016
    Glad I joined this forum, thanks!
  36. #336
    Jul 2016
    Thanks for the info!
  37. #337
    Jul 2016
    More helpful info. Great!
  38. #338
    Trail Ninja
    Reputation: Varaxis's Avatar
    Need clarification on what *exactly* Braaaaap means.
    A) Sound that a tire makes when it is pushed to its limits
    B) Sound of a 2 stroke gasoline engine
    C) Other (explain)
    Need a definition check for: "50:01" - Love back wheel.
    - Apparently it stands for the ratio for the percentage of weight placed on the rear wheel, and to the front, implying riding the back wheel with the front having only enough weight to not keep it from flying backwards in a manual.
    Also need a nomenclature check on the nut that tightens down a tubeless valve. Valve lock nut?
    Spec E29c
    Niner ROS9 SS
    Trek Crockett
    Be part of the solution, not the pollution.
  39. #339
    Dirty triathlete
    May 2015
    Quote Originally Posted by Varaxis View Post
    Sound of an accelerating 4 stroke motorcycle. Often mistakenly used as the sound of a smoker, when anyone has raced knows that 2 strokes are "ring dingers". Drives me nuts.
    "Braaaaaap" = riding hard
  40. #340
    Reputation: khagan's Avatar
    Aug 2016
    nice post.
  41. #341
    Aug 2016
    Awesome
  42. #342
    Jul 2016
    Took me a bit to figure out what DJ was...
  43. #343
    Disc jockey, duh. Love me some disc jockey bikes
  44. #344
    Jul 2016
    Yup. I'm partial to the Kona "Wolfman Jack" and the Cannondale "Rick Dees", myself.
  45. #345
    Sep 2016
    RTFM: A strong recommendation to read the manual, normally used after the fact in a context.
  46. #346
    Dec 2016
    Thanks for the insight!
  47. #347
    Reputation: Shotgun Jeremy's Avatar
    Mar 2017
    Good stuff! More forums should have this.
  1. Freeride Glossary
    By crash_test_dummy in forum Downhill - Freeride
    Last Post: 01-15-2012, 01:34 PM
  2. Glossary of terms.... Pro Pedal, SPV?????
    By Beowulf in forum Shocks and Suspension
    Last Post: 01-15-2012, 10:38 AM
  3. Beer Glossary, Guide and FAQ
    By fc in forum Beer Forum
    Last Post: 01-20-2011, 10:45 PM
  4. glossary of terms and abbr?
    By wildman in forum Beginner's Corner
    Last Post: 09-21-2004, 09:10 AM
  5. MTB Glossary (Please Help)
    By Harvo in forum Passion
    Last Post: 01-31-2004, 06:37 AM
