Results 1 to 6 of 6
Thread: MTB Shoes
    May 2012
    MTB Shoes
    I noticed some shoes have to holes near the tip of the shoe (not for cleats). My shoes also came with two metal studs, which i assume screw into these holes.
    What are they for and should I use them? lol thanks
    Fat-tired Roadie
    Nov 2007
    They're to help in running up hill. Mostly for cyclocross racing, although it's relevant now and then in XC too.
    I think they make the shoes a little less user-friendly for general trail riding. If you're picking your way across stepping stones, for example, it's that much more awkwardness going on under the balls of your feet.
    T.W.O.
    Reputation: mimi1885's Avatar
    It helps when you are walking uphill on loose dirt but in general not really helping much. I took mine off.
    Sent from my iPhone 4s using Tapatalk
    Fat & Single
    Reputation: ozzybmx's Avatar
    Quote Originally Posted by 16k-rpm View Post
    Mud studs.
    I screwed them in for winter races, they definately help get some walking traction if you spin out on a muddy hill, if your not racing i wouldnt bother because they are not friendly over rocks or trees.
    Evil Following
    Trek 9.9 Superfly SL
    IndyFab Deluxe 29
    FM190 Fatty
    Pivot Vault CX
    Cervelo R3 Disc
    Sep 2012
    I dont use cycling shoes any more found them uncomfortable, i find a good pair of hiking boots works much better
    my shimano shoes came with the front cleats, can you take them off without the fancy tool that shimano shows?
