    Nov 2013
    MTB problem with front derraillour and shimano crankset
    I have just bought a new shimano deore crankset to my MTB. I already have a Shimano deore front deraillour, which fitted with my last shiman crank. The bottom bracket is a octalink v2. When i put on my new shimano deore triple mtb crankset. MY front derraliour cant get to the last chainring. I can se from my last crankarm, that the new deore chainrings are further away from the front derrailour. I am really in doubt, what to do??. They should fit perfectly.
    Jan 2009
    what model is your crankset? it should have a model # printed on it, something like "FC-M430." from that, you can look up the PDF tech doc on Shimano's website and figure out what length BB spindle you are supposed to use with that crankset. it sounds like the BB you have now is too wide and you need a narrower one.
    Nov 2013
    Jan 2009
    here is the info you need: http://techdocs.shimano.com/media/te...9830657937.pdf
    you need a 110mm or 113mm BB. not sure which (someone clarify this!?) what length do you have now? if you're not sure, pull the crankset and measure it or pull the BB and measure that too.
    did you do this at home or did a bike shop do it? if a bike shop did it, they should have checked before slapping a crankset on the wrong size BB.
  1. Shimano 2x XTR 986 Front Derailleur Problem
    By Lycra Matt in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-27-2014, 06:24 AM
  2. Can this front shifter be set for a triple crankset? Shimano SLX sl-m660-10A
    By Imho4ep in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-25-2013, 10:06 AM
  3. Problem pulling my Shimano XTR FC M900 Crankset
    By Back-N-Black in forum General Discussion
    Last Post: 11-11-2012, 11:46 AM
  4. Problem aligning XT front derailleur/crankset
    By intoflatlines in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-03-2011, 01:33 AM
  5. Replies: 3
    Last Post: 02-19-2011, 10:06 PM
