Results 1 to 16 of 16
    Reputation: Wilkoturbo's Avatar
    Morning all hope hubs :(
    Hi all I'm trying to build my own wheels bought hope pro 2 hubs plus mavic 317 rims what size spoke do I need plus any advice , many thanks Paul
    Anyone
    Picture Unrelated
    Reputation: zebrahum's Avatar
    Jun 2005
    You're trying to build your own wheels but don't even know how to find the correct spoke size? I think everyone's trying to be nice by staying out of this thread and not bashing you.
    I can honestly say that you should try and pick up a book on wheelbuilding and read that before you jump into this project. "The Art of Wheelbuilding" would be an ok place to start. There must be videos on youtube as well.
    Here's a good place to start, you might be able to get going using this:
    http://www.sheldonbrown.com/wheelbuild.html
    One of the most commonly used tools for wheelbuilding is a spoke calculator, here's one:
    http://www.dtswiss.com/SpokesCalc/We...px?language=en
    or: http://lenni.info/edd/
    It would be a good idea to quickly learn about hub measurements and either find them on Hope's site or measure them yourself (use Sheldon's website linked above) that way you know the measurements you put into the spoke calculator will work.
    Other than that, make sure you have some spoke prep or at least locktite on those spoke ends so they don't come back apart when you assemble it. Good luck!
    Hey thanks for the advice and the links made good reading I will be trying this weekend
    Wish me luck ha ha
    Many thanks Paul
    Picture Unrelated
    Jun 2005
    Quote Originally Posted by Wilkoturbo View Post
    Wish me luck ha ha
    Many thanks Paul
    Good luck, be patient, and prepare to fail once in a while. It's all part of the process.
    My favorite way to build wheels is after lacing to bring all the nipples to a common point; usually I leave 2 threads showing or something like that. Then slowly add tension around the wheel evenly; I'll usually start with two turns on every spoke for a round then come back around for a turn each a time or two then start working in half turns and quarter turns. The slower you add tension the more evenly the wheel should build up. Once you get near your tension then you can start tweaking your pattern to include truing the wheel and rounding the wheel.
    Yes, that's fonetic
    Reputation: whoda*huck's Avatar
    Feb 2005
    Do you have a truing stand? I can't imagine building a wheel from scratch w/o one.
    Yeah got all the bits now plus a stand I'll see how I go on if not the local bike shop will help out
    Yes, that's fonetic
    Feb 2005
    Good luck then. Listen to Zebra and don't forget the spoke prep/locktite and check the tension after a ride or two.
    All done many thanks
    Good job. It's always better to learn how to do it yourself. It gives you a better understanding of quality and how everything works together.
    Just Ride !
    Reputation: C.M.S's Avatar
    Nice touch with the red hubs and red nipples..
    Hit the trails with your bike and get freaky.
    Jan 2009
    I have built tons of wheels without a truing stand. zip ties on the chainstays!
    Reputation: Porschefan's Avatar
    Jan 2011
    Also...do a search in the Wheels and Tires forum here on MTBR. Lots of pointers to great websites, books, tools, methods over there.
    The secret to mountain biking is pretty simple. The slower you go the more likely it is you'll crash. ~Julie Furtado
    Hey thanks guys I did try zip ties but gave up was luckily a mate had a jig , as for the more info thanks I might build some more one day
    Everyone loves red nipples lol ha ha ha
    poser Administrator
    Reputation: rockcrusher's Avatar
    Aug 2003
    remember to retension your wheels after a couple hours of riding especially if you didn't relieve the tension and retension them while building. They will bed in and the tension will decrease making the wheel loose.
    Once retensioned they should be good but I always make an attempt to check tension on my wheels (which I build) every couple of months. Good preventative maintenance, just like checking chain wear.
    Try this: HTFU
  1. Replies: 7
    Last Post: 10-06-2012, 12:28 AM
  2. Hope pro II Hubs vs. BWW hubs.
    By CRed in forum Wheels and Tires
    Last Post: 08-06-2009, 04:09 AM
  3. DT hubs and Hope Pro II hubs for a clyde
    By brain3278 in forum Wheels and Tires
    Last Post: 03-16-2009, 11:10 AM
  4. Replies: 96
    Last Post: 01-14-2007, 08:01 PM
  5. XTR hubs vs. Hope, DT?
    By KonaSS in forum Wheels and Tires
    Last Post: 03-26-2006, 06:43 PM
