Results 1 to 5 of 5
Thread: mix of brands
    mix of brands
    Have anyone had any problem mixing shimano with sram? Like have a shimano rear derailer and a sram front derailer with shimano crankset, etc,etc?
    Bicyclochondriac.
    Quote Originally Posted by mutak
    Have anyone had any problem mixing shimano with sram? Like have a shimano rear dérailleur and a sram front dérailleur with shimano crankset, etc,etc?
    The only thing you need to worry about is using a SRAM 1:1 rear shifter with a shimano rear dérailleur, or vise-versa. The reason is that the SRAM shifter/der system uses a different cable pull ratio (1:1) than shimano (2:1). SRAM does make a few 2:1 shifters that will work with just shimano rear dérailleurs. This page shows which shifters are shimano compatible (2:1)
    http://sram.com/en/srammountain/index.php
    Everything else is compatible.
    pedal pusher
    Reputation: f3rg's Avatar
    I have Sram twist shifters and a Shimano front derailler, and they work great together. In fact, I prefer the twist shifters because I can more easily get rid of the occasional chain rub on the FD by clicking one spot up or down on the shifter. The FD will move just enough to not hit the chain, but not enough that it allows the chain to shift to a new gear.
    For the rear, keep the 2:1 and 1:1 ratios of each brand in mind when making purchases.
    Thanks for the info! I have a rear Sram x-9 and a front Lx, and I can't find the right fine tuning with the limit crews on the derailers and the cable tension (using the barrels of the shifters) to have a smooth shifting like on my low end hybrid bike. I guess I'll have to go at my LBS and pay the price to have that adjusted.
    Riding free's the mind
    There isn't much tolerance in the adjustment factors with drivetrains to achieve quiet no-rub shifts. I've tuned and installed multiple drive trains on my bikes and still break out the instruction manuals from SRAM or Shimano to get the procedure right.
    Question to a custom frame builder..."So what makes your bikes climb better?"....his answer, "Uh, your legs?"
