Results 1 to 3 of 3
    baka baka!
    Reputation: x9typesh's Avatar
    Lubing Suspension Pivots
    hi,
    i own a marin quad tara and was wondering if i have to lube the pivots after every ride. i've been riding across creeks and streams lately so the links get pretty gunked up with mud and debris. what lubes\grease should i use? i have boeshield and park polylube on hand.
    thanks,
    jon
    enjoying the kool-aid
    Reputation: Chewieez's Avatar
    I would steer clear off just putting lube on the pivots. The pivots should have either bearings or bushings which will be internally lubed.
    After wet rides, it is a good idea to hose off the bike (not hard water on shocks/headsets/bottombrackets) and clean the drive chain really good (get the cassette clean with a brush). Towel off the bike and let it dry outside in the sun if you can. Don't let it sit somewhere will it will have trouble drying. Maybe sure there isn't any water inside the frame that would of gone in down the seat tube. You can let the bike dry upside down with the seat post out.
    You shouldn't have many issues with the pivots. Have a shop check the condition of the bearings/bushings atleast once a year. You should get aleast a year out of the bearings.
    Just putting lube on the outside of the pivots will just attract more dirt and grime and will help very little.
    baka baka!
    thanks for the advice!
