Results 1 to 6 of 6
    Low-riser bar or flat bar
    What are the differences and the strengths of each? If it is a personal preference, why do you prefer one over the other. I am trying to decide.
    Reputation: JonathanGennick's Avatar
    Ok. I will 'fess up and admit that I prefer the "look" of a riser-bar.
    There. I've said it. I'm so ashamed.
    As far as strengths of one over the other, the real issue to think about is how leaned over you want to be. I have a couple of bikes that I made rideable -- for me -- by changing the rise of my bars.
    It is more about fit, rider preferences, and the purpose of the bike than it is strengths vs weaknesses.
    Flat bars will make you lean over more, so there will be more weight on the bars and front wheel. This is a good position for climbing, so you see this setup most often on XC trail/race bikes. But while that position is good for climbing, it won't work as well for descending. Like Jonathan mentioned, changing the rise is also a way to adjust the fit of your bike.
    Former Bike Wrench
    Flat bars are generally lighter at the same strength than riser bars. It use to be that to get a wider bar with more back sweep...you had to go with a riser. That is no longer the case, several companies such as Salsa, Niner, and Titec offer flat bars with the same width and sweep as riser bars. And the height can be adjusted with the stem rise so you are not necessarily bent over more than a riser bar.
    I rode riser bars for over ten years because that was all there was for wider bars with a nice back sweep. But now days, I ride a wide flat bar because my 29er has a higher front end and I like my hands to be lower. My flat bar weighs ~100 grams lighter than the equivalent riser bar.
    In the end, its all choice...but you can get the exact same hand position in a flat bar with a higher rise stem as you can with a riser bar.
    This kind of off topic, but is it possible to raise the height of the handle bars at where the stem connects to the fork?
    If you have extra room on the steerer tube, you'll have spacers above the stem, you can swap the stem and the spacers around, making the bars higher.
    If you don't have any more room on the steerer tube, you can get a stem with more rise.
