    begginer
    Caution;  Merge;  Workers Ahead! Looking for good starting bike
    I am just strating out with some single track stuff and would like some advice on getting a new bike.
    1-What is the best kind of shifter?
    2-How many gears?
    3-What is the best bike for a tight budget?
    Mar 2005
    I started out w/ a khs alite 300 for my first mtn. bike and just picked up a new bike. Both of my bikes are 21 speeds and that adquate's for what I do.
    Work Hard, Play Harder
    Reputation: Ice25gt's Avatar
    Mar 2006
    1)Top of the line shifters/derailleurs are Shimano XTR, or SRAM X-0.
    2)Gears vary, but I use a 27 speed drivetrain
    3)The best bike to start out on is going to be the best bike that you can afford, and you feel comfortable on
    Here's some advice. You definitely don't need to go top of the line unless you plan on racing. XTR and X-0 are very expensive, and only come equipped stock on the really high end bikes. You can get a bike equipped with lower lower level shimano or sram components for alot cheaper and they will be fine for any type of riding that you are going to do. If you think that you are going to be riding alot, and stick with mtb'ing, then you should definitley buy the best bike that you can afford right from the start. It will cost alot more money in the long run to upgrade a lower level bike, and you'll end up with a lesser quality frame most likely. Check out bikes from TREK, Giant, Specialized, Rocky Mountain, Gary Fisher, Klein and any other brands that your LBS might carry. See what feels the best and make a decision based on that. Good luck
    06 Rocky Mountain ETSX - Full XTR, Fox Shox, Crossmax XL Wheels
    Reputation: InvictaS1's Avatar
    Mar 2005
    most mountain bikes now have either 24 (3 in fornt 8 in back) or 27 (3 in front 9 in back) gears. 24 is plenty and thats whats on most entry level bikes.
    as far as bikes go id expect to spend at least $300 on a new bike. trek, giant, specialized, ironhorse, and jamis ect all have good entry level bikes.
