Results 1 to 3 of 3
    Reputation: SocalTeknique's Avatar
    Sep 2012
    Long seat post good idea?
    OK I've searched and finally found a Kona Coiler that I wanted. I've ridden it a couple times and and upgraded some parts but now i realized that I need about two more inches to ride more comfortably. The current post is at it minimum insertion mark and am thinking about getting a (Thompson) 410mm post. Would the frame handle the stress? Or should I look for a medium (17") frame? I'm 5.9' 165 lbs and 15" frame.
    Sent from my Nexus 7 using Tapatalk 2
    Moderator Moderator
    If you're looking for 2 more inches on top of what's showing in the pic, I'm going to say you should move to a larger frame.
    I would also seriously consider a longer stem. If the type of riding you're doing is calling for a high seat position, you'll also benefit a lot from a more stretched out cockpit. If you could try out a 70/90 mm, I think you'll t like it.
    Sep 2012
    Re: Long seat post good idea?
    Yeah a longer stem is next on my list. Can I run a longer stem with triple crown (clamp?) forks?
  1. Replies: 68
    Last Post: 10-01-2013, 06:31 AM
  2. Use seat post shim good idea?????
    By gonzo in forum Frame Building
    Last Post: 04-28-2012, 12:20 PM
  3. Replies: 8
    Last Post: 02-05-2012, 01:36 PM
  4. Reverb Seat Post, great idea, poor design
    By Sawyerdog in forum Ibis
    Last Post: 11-03-2011, 09:40 AM
  5. X-post Grip brakes - good idea
    By jeffgothro in forum General Discussion
    Last Post: 07-26-2011, 06:07 PM
