Results 1 to 12 of 12
Thread: Lock out??
    Lock out??
    When exactly should I be locking out my forks?
    What could go wrong ...
    Reputation: Zoke2's Avatar
    Nov 2007
    lockout is typically used when climbing steep terrain
    I used to ride to Win ... Now I ride to Grin
    While my guitar gently weeps, my bike sits there mocking me
    To add on to the question:
    I stumble upon a steep unexpected climb, I don't have enough time to lockout both fork and rear shock: which do I choose first?
    -james
    2000 Trek 6500 HT
    2008 Ibex Asta Comp X7 FS
    rear
    Quote Originally Posted by Woods1986
    The only time that I use my fork lockout is when riding through deep sand. I've found that engaging the lockout dramatically increases steering control through the sand.
    I know that hill climbing is commonly cited as an example of where you'd use fork lockout, but IMO, it has to be a long smooth climb with some out-of-the-saddle sections for it to be worthwhile.
    Quote Originally Posted by yimmy149
    Neither. IMO, it's best to have an active suspension on steep rocky climbs.
    Reputation: nachomc's Avatar
    I don't like using my lock out. I have a harder time climbing with it on. For short steep climbs, if you have a lockout option on your rear shock, it's probably not worth fiddling with it as the climb is fairly short. Just hammer it out. On a longer climb, set the stiffer setting for the rear shock and go for it.
    :wq
    I just use the lockout when riding on paved roads.
    Reputation: bada!'s Avatar
    I also only use the lockout option on road anything else is off.
    Ride On
    Reputation: IRussell's Avatar
    Quote Originally Posted by Resist
    me three.
    And don't forget to tweak your fork (rebound, preload, etc...) to tune it to terrain and preference.
    Quote Originally Posted by IRussell
    I am still trying to figure that out. I know how, just not sure what setting is good for specific terrain.
    Baton Rouge, LA
    Reputation: StompinStu's Avatar
    Quote Originally Posted by KevinB
    Ditto.
    Don't focus so much on using all the bells and whistles on your gear. Focus on solid riding techniques and picking choice lines.
