Results 1 to 6 of 6
    Feb 2012
    Upset Just got my New Goblin Need help with the drive train..... rear derailleur looks bent
    Like the title says I just got my bike in today and was so excited to set it up and ride however things in the drive train seemed pretty messed up. This is my first mountain bike so I'm pretty new to the game however I have watched about 8 videos on how to set up the rear derailleur and I still cant get it to work. I also looked in the Newbie sticky and tried his explanation. I would really like to get this fixed so I can ride to work tomorrow but at this point it doesnt look good. Please advise.
    -Will
    Reputation: J.B. Weld's Avatar
    It's normal for a new bike to need derailleur adjustments- limits, cable tension. etc., and a lot of times the derailleur hanger needs aligned as well. If your derailleur looks bent you definitely need to put a tool on the hanger and see what's what.
    Feb 2012
    I think I have figured out the L and the H screws but now my problem is that its jumping gears if i push the lever all the way down.
    It could be a bent chain or chain ring. You shouldn't of had to adjust the L and H screws.Derailleur adjustment can be tricky .Start with the chain in the smallest gear ,get the cable mostly tight ,try shifting ,if it doesn't shift ,tighten the cable until it does.
    Usually the derailleur isn't bent. The derailleur is attached to a hanger. Often this gets bent.
    It can be bent when you look down on it from above, left or right. It can also be twisted clockwise or counter clockwise.
    I have straightened a derailleur by eye by grabbing it at the top and bending the hanger derailleur assembly left or right. For a twist I have used a lockjaw pliers carefully to rotate it.
    A lbs can do it better by using a gauge, if you want to take it in.
    Feb 2012
    Although I still suspect that something is bent, I was able to get it up and running for its first offical ride this morning and all I can say is I am one happy man. It shifted pretty well, didn't give me a hard time at all but my legs hate me at this point. Thanks again for the responses I really do appreciate it.
    -Will
  1. Replies: 6
    Last Post: 05-02-2014, 05:04 PM
  2. Replies: 2
    Last Post: 08-19-2013, 01:52 PM
  3. Bent rear derailleur?
    By johnb in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-01-2013, 08:22 AM
  4. Sram XX1 1 x 11 drive train. What rear hub?
    By FrY10cK in forum Fat bikes
    Last Post: 11-12-2012, 01:16 PM
  5. Replies: 1
    Last Post: 07-03-2011, 04:29 PM
