Results 1 to 10 of 10
    Jan 2014
    Judging a Mountain Bike in a Parking Lot
    Iím trying to get back into mountain biking after a several year hiatus. In looking for a new bike, Iím trying to follow the general advice of buy what feels right.
    While this makes sense, Iím wondering if what feels best in the parking lot will feel good on the trail. The bikes Iíve tried out that I like are all fairly stiff with a snappy feel (specifically, the Specialized Camber and Cannondale Rush). Whereas the softer bikes (Giant Trance/Anthem, Trek Fuel) havenít felt very good in the parking.
    How well does riding in the parking lot translate to the trail? Should I still get the best feeling bike, or should I try to guess how it will feel on rough terrain?
    Reputation: Shakester's Avatar
    Jun 2012
    I wouldn't concentrate on how soft or harsh the suspension feels on concrete. When test riding a bike at a shop, you're looking at fit and how your body feels with the bike's geometry. The suspension could always be adjusted and should be before heading out to the trails. There isn't a common suspension setting so bikes in a shop can differ in feel from one to the other.
    Fat-tired Roadie
    Nov 2007
    Do you still have your old bike?
    Do your local shops offer demos? The two big local shops in my area do. It costs money, but you can probably get a little movement on price to offset that.
    If you can't get on a trail to demo, at least try to get rad. Ride up and down curbs, banks, stairs, whatever you can find.
    Try to get some help setting up suspension. When I demoed Giant's XC bike, it felt, if anything, too firm.
    If you really can't tell, all the bikes you mention would be fine to start on. Go with your gut.
    Kitty! Kitty! Kitty!
    Reputation: GelatiCruiser's Avatar
    Oct 2012
    Parking lot riding tells you a lot about feel, fit and comfort on the bike but does not translate to trail riding..... Really at all. I'd try what Andrew said... See if they have a demo day at your lbs and actually try it out.
    I tried a couple bikes in the parking lot and immediately felt the most comfortable on the bike I ended up buying.
    Picture Unrelated
    Reputation: zebrahum's Avatar
    Jun 2005
    I wouldn't say that the parking lot test doesn't translate to the trail at all. You can get a feel for how the bike handles at high and low speeds, you can get a feel for how easy or difficult the front wheel is to get off the ground, and the most important thing about a bike on the trails is how it fits.
    Suspension between those bikes is different and is almost certainly set up differently so making comparisons is difficult. I think of it as the more suspension travel and the easier the travel moves the more it will smooth out bumps generally at some amount of loss in efficiency to pedaling. Unless you're racing or your trails are glorified dirt sidewalks most people find the "softer" bikes easier to work with on the trail.
    Like Andrw said, get them on dirt if you can. If not try and find things to ride over on your test ride. As long as you don't damage the bike or get it dirty the shop should let you give it a bit of a beat. If there's a stair set nearby go ride down it, drop off a curb or two, hit some potholes (ones that aren't full of water or you're going to get banned from test rides), do what you can to simulate a trail. Hang your butt off the back like you're dropping a steep chute, stand up and hammer, do some low speed tech moves. You can learn just about anything you need to know to make a decision about one bike vs. another with a decent parking lot test.
    Reputation: sml-2727's Avatar
    Nov 2013
    The parking lot ride is kinda useless more or less. The two bikes I was testing where the Camber comp and 27.5 Giant trance, being a bigger guy I just felt better on the 29er.
    Bicyclochondriac.
    I'd use the parking lot to ball-park the fit.
    But in terms of suspension performance, and geometry feel on the trail, it does not tell you much.
    Jul 2013
    The parking lot is enough for me to feel the difference between a 26" and a 29" Hardrock.
    What works for me may not work for you. What's best for you depends on many factors. We are different from each other.
    Reputation: Bigb2000's Avatar
    May 2013
    Do you know anybody that rides already? If so, ask to ride theirs on the trail. If not, try to demo or rent a few bikes from LBS you plan on buying from. Most will deduct the rental cost from purchase. Tap into the knowledge of the shop. They should be familiar with the local trails and your riding preferences. Personally, don't think you can wrong with either the fuel or camber.
    I Tried Them ALL... SuperModerator
    Reputation: Cayenne_Pepa's Avatar
    Try doing slalom on asphalt to see how the bike corners. Also, try finding some rock features to feel how the bike plows through it. Lastly, see how it climbs, if at all possible.
    "This is a male-dominated forum... there will be lots of Testosterone sword-shaming here" ~ Kenfucius
  1. Useful rule of thumb metric for judging Bike Light Value !
    By androgen in forum Lights and Night Riding
    Last Post: 09-12-2013, 04:32 AM
  2. Performance Bike models are staring, judging you...
    By Dion in forum General Discussion
    Last Post: 06-05-2012, 10:43 AM
  3. Canfest judging shocker
    By JFryauff in forum Beer Forum
    Last Post: 11-16-2011, 10:16 AM
  4. Used needles at Green Mountain parking lot.
    By aeros in forum Washington
    Last Post: 10-17-2011, 09:42 AM
  5. Can we tighten up the judging?
    By SentralSteve in forum Downhill - Freeride
    Last Post: 09-11-2011, 09:59 AM
