Results 1 to 24 of 24
    Bikecurious
    Its log, its log, its big, its heavy, its wood.....
    And sometimes its a little too big to get over. I can clear most logs as long as my chainring can clear them, but how to you get over the bigger logs? What are some of your tricks/tips? Thanks.
    Flying Goat
    Reputation: mrpercussive's Avatar
    Quote Originally Posted by g-bus
    pop off them instead of rolling them...
    mbtr member
    Reputation: scottzg's Avatar
    1) install bashring
    2)level out cranks
    3) pop front wheel over log
    4)smash bashring into log
    5)lean forward and crank
    6)?????
    7)profit.
    You can get over any size log so long as you catch the log between your bashring and crank arm and have enough speed to tip forward over it. If you don't have a bashring, be sure to be in the large chainring.
    "Things that are complex are not useful, Things that are useful are simple."
    Mikhail Kalashnikov
    if you don't like your bike, you can dig a couple teeth from your big chainring into the log and pedal through it. you will bend a tooth or several, eventually. good way to rationalize buying better gear: "honey, it's broken, i need this raceface crank and bash guard!"
    Flying Goat
    Pop off the log... Your chain rings wont even tough it...
    <a href="http://vids.myspace.com/index.cfm?fuseaction=vids.individual&videoid=36282 769">Alex popping off the log</a><br/><object width="430px" height="386px"><param name="wmode" value="transparent"/><param name="allowscriptaccess" value="always"/><param name="movie" value="http://lads.myspace.com/videos/vplayer.swf"/><param name="flashvars" value="culture=en-US&a=0&ap=0&y=0&m=36282769&userid=-1&showmenus=0&remove=0&t=&type=video"/><embed src="http://lads.myspace.com/videos/vplayer.swf" width="430" height="386" flashvars="culture=en-US&a=0&ap=0&y=0&m=36282769&userid=-1&showmenus=0&remove=0&t=&type=video" type="application/x-shockwave-flash" allowscriptaccess="always" /></object>
    tlg
    tlg is offline
    (enter witty phrase here)
    Reputation: tlg's Avatar
    good ren and stimpy reference btw.
    Reputation: 1996cc's Avatar
    I'd like to see that video take place in the real world. i.e. a wet, ROUND, moss or mud covered, off camber, at an angle to the trail, log. Where when you set the front tire on it, it slides out from under the bike and you take a dirt/log sample.
    2018 Transition Patrol
    Nervous Descender
    Reputation: Adirondack Blues's Avatar
    Quote Originally Posted by 1996cc
    That's how I jump 'em (adk sports vid). Works for rocks, benches, ROUND logs, off camber logs, etc. Of course, there are exceptions where this isn't always the best technique.
    Check out some of our local hills: CDRC (Capital District Road Climbs)
    Reputation: spazzy's Avatar
    well you can bump your front wheel over the log and then grab some front brake so you endo alittle and then let go and you should be able to kinda hump your way over the log, (without catching your big ring in the log) i do that when i dont pop off of them
    tlg
    tlg is offline
    It does work in the real world. The real world isn't always wet, mossy, muddy, and off camber. That being said, sure when you've got a wet, mossy, muddy, off camber log it's tricky if not down right dangerous. But in those conditions, any method of going over a log will be sketchy.
    The main disadvantage of this technique is you need momentum. It always seems that when I come to a log, it's right after a sharp blind corner where I don't see it, right before a corner where I need to slow down, or on a climb where you just don't have the momentum.
    It's best used when you've got momentum, rather than slowing down and using a chainring/bashring grind.
    I know this isn't an option for the mt dew swilling xtreme guys but you could always walk the bike over the obstacle if need be. works well for me.
    Bikecurious
    Thanks, got some good ideas here, but what works best on a climb? When you're on a slow climb and can't build enough speed to pop off of it or hop it? I've also found the technique of dismounting and carrying my bike over the obstacle to be quite effective, but I thought I'd look into some alternative methods.
    tlg
    tlg is offline
    Pop the front wheel over the log, dig your chainring into the log, and pedal over. The trick is being in the right gear. Too easy, and when your back tire hits the log, it'll spin out on you. Too hard and you won't have the momentum to get over. Also you have to time your pedal stroke right so that the down stroke doesn't hit the log.
    Nervous Descender
    Uphill- you need to learn to lunge the bike up and over the log, either by using the pedaling lunge or a hopping lunge, You don't need to destroy your chainring. Watch the trials guys ride up or pedal up onto an obstacle for an extreme example of this. Its mostly momentum and weight shift.
    Is that Bill rated?
    Reputation: Lord Humongous's Avatar
    Lunge
    When riding uphill you can get over most logs and rocks from a dead stop with some body language. The easy part is to get your front end over, then move your body forwards and up so that as much of your weight is over the front of the bike as you are capable of. When you are in position like that simultaneously kick down and back on your pedals and pull the bar up and push it forwards. Your centre of gravity should stay in nearly the same position, but your body will lower as your bike moves up and over the obstacle. Pedal away and listen to the oohs and ahs from your riding friends.
    I would start practicing this on every lip you see, uphill or on flats, even if you would normally just pedal over them until it becomes second nature.
    Well, it was a good try.
    Reputation: onegymrat's Avatar
    Scroll down and watch the teaser video. This is Lars Sternberg j-hopping a log. This is a fantastic training video, btw.
    http://fluidride.com/2008/03/26/flui...e-a-pro-video/
    Dirt Deviant
    Reputation: savagemann's Avatar
    Quote Originally Posted by frank ingram
    Here is what Chuck Norris would do.
    First he would curse at the log, then right before he hits it he lifts his front wheel and smashes it down ontop of the doomed log, sending it flying into a bazillion toothpick sized pieces.
    But, I guess if it is too sketchy, walking over it is ok in most cases, if you aren't chuck.
    Look, whatever happens, don't fight the mountain.
    Bikecurious
    Quote Originally Posted by savagemann
    More importantly, what would Brian Boitano do? I bet he'd kick an ass or two, that's what Brian Boitano'd do.
    Flying Goat
    The log will move itself once they see Jack Bauer about to hit it...
    Certified Porsche Tech
    Reputation: Mrledzeppelin's Avatar
    Cool-blue Rhythm
    My 2 cents:
    Sorry this thread needed more Ren and Stimpy
    Odin! Guide our ships, our axes spears and swords!
    SSolo, on your left!
    Quote Originally Posted by onegymrat
    Nice action and looks like a good instructional vid.
    Get off the couch and ride!
    Reputation: Sticky Fingers's Avatar
    I almost more glad that this thread is about Ren and Stimpy than it is about a log jumping technique.
    [08' Windsor Ghost 6500]
    Rock Shox Dart 1 - Tektro Discs - WTB Velociraptors - Alex DP17 rims
    Ride it like you stole it.
    Bikecurious
    Happy happy joy joy! Btw, I managed to make it over a rather large log that had been plaguing me for some time now. Thanks for the tips.
