    Jun 2012
    Integrated Headset gap?
    Hi, I have a gap between my integrated headset and the frame. This gap goes away if I remove one of the silver washers. Is the picture below normal or not?
    Jun 2012
    Fat-tired Roadie
    Nov 2007
    When you say "silver washers," are you referring to the spacers between your headset and your stem? Or to something else? If something else, where does it come from?
    Regardless, it's weird that the top of the headset isn't all the way in contact. Can you move it further down with your fingers? If no, take it to your shop and get it fixed. If yes, how far above the top of the steer tube is the top of your topmost spacer?
    Loosen the stem, screw down the hex bolt on the top cap until the gap goes away. Then tighten your stem. Park Tool has a good blog post on this.
